System description: Ubuntu 11.10, 64-bit, with ROS Fuerte installed
I followed the directions for the "non-ROS" installation of RGBDSLAM, as indicated here:
ros.org/wiki/rgbdslam#RGB-D_SLAM_for_Non-ROS_Users
The process is smooth until the very end, where I attempt to make the package, using:
rosmake rgbdslam_freiburg
The error occurs during compilation; the terminal output is as follows:
[ 34%] Building CXX object CMakeFiles/rgbdslam.dir/src/main.o In file included from /home/magnate/ros/rgbdslam_freiburg/rgbdslam/src/ColorOctomapServer.h:4:0, from /home/magnate/ros/rgbdslam_freiburg/rgbdslam/src/graph_manager.h:31, from /home/magnate/ros/rgbdslam_freiburg/rgbdslam/src/openni_listener.h:30, from /home/magnate/ros/rgbdslam_freiburg/rgbdslam/src/main.cpp:17: /opt/ros/fuerte/stacks/octomap_mapping/octomap_server/include/octomap_server/OctomapServer.h:50:48: fatal error: octomap_server/OctomapServerConfig.h: No such file or directory compilation terminated. make[3]: *** [CMakeFiles/rgbdslam.dir/src/main.o] Error 1 make[3]: Leaving directory
/home/magnate/ros/rgbdslam_freiburg/rgbdslam/build' make[2]: *** [CMakeFiles/rgbdslam.dir/all] Error 2 make[2]: Leaving directory
/home/magnate/ros/rgbdslam_freiburg/rgbdslam/build' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/magnate/ros/rgbdslam_freiburg/rgbdslam/build' -------------------------------------------------------------------------------} [ rosmake ] Output from build of package rgbdslam written to: [ rosmake ] /home/magnate/.ros/rosmake/rosmake_output-20130211-032124/rgbdslam/build_output.log
[rosmake-0] Finished <<< rgbdslam [FAIL] [ 13.96 seconds ]
[ rosmake ] Halting due to failure in package rgbdslam. [ rosmake ] Waiting for other threads to complete.
[ rosmake ] Results:
[ rosmake ] Built 47 packages with 1 failures.
[ rosmake ] Summary output to directory
If anyone has insight about what the issue might be, and how it could be resolved, it would be much appreciated.
Originally posted by magnate on ROS Answers with karma: 28 on 2013-02-10
Comment by magnate on 2013-02-11:
@Felix-Endres (below): Thanks mate, that was it.
