Try to echo the image topic with rostopic echo <camera_node>/image_raw
. If there is nothing in return, then there may be a configuration problem.
In this case double-check that ROS_MASTER_URI
and ROS_IP
environment variables are correctly set on both computers.
Originally posted by Boris with karma: 3060 on 2013-02-06
Comment by jd on 2013-02-06:
I run
rostopic echo /camera/rgb/image_raw
And I never get any response back from the terminal. But at the same time if I do
rosrun image_view image_view image:=/camera/rgb/image_color
I can see the camera image.
Comment by Boris on 2013-02-06:
Did you check ROS_IP
and ROS_MASTER_URI
? I had the same issue a while ago and the problem was indeed in these.
I got it working, somehow. Not sure what, if anything, I did though. I have trouble now though with losing the network connection. Shortly after the workstation gets the camera image it just freezes and I can't ssh to the robot anymore.
It can be a problem of network bandwidth. Try to use compression -- Transport Hint
in Camera
plugin in RViz.
