Hi,
I have problem with subscriber, when I run my android application a see in LogCat that "Unable to resolve host "ROS": No address associated with hostname".
I have set in .bashrc
ROS_IP=10.0.0.139 , ROS_HOSTNAME=10.0.0.139 , ROS_MASTER_URI=http:// 10.0.0.139:11311
In file /etc/hosts
127.0.0.1 localhost , 127.0.1.1 ROS
and in file /etc/hostname
ROS
If I create publisher it's all OK, but subscriber is still wrong. Do you know where is problem ?
Originally posted by LeopoldPodmolík on ROS Answers with karma: 66 on 2013-02-05
Problem solved.
The problem was in file .bashrc, where I had only
ROS_IP=10.0.0.139
when I write full command
export ROS_IP=10.0.0.139
all will be OK. I recognise by this code in shell
python -c "import roslib.network; print roslib.network.get_address_override()"
because return NONE, what was wrong ...
Originally posted by LeopoldPodmolík with karma: 66 on 2013-02-06
