I want to create a package with just one header file and use this header file from other packages.
The header file is in HeaderProjectName/include/HeaderProjectName/HeaderFile.h
In the CMakeLists.txt "catkin_package(INCLUDE_DIRS include)" is defined and so is "install(DIRECTORY include/${PROJECT_NAME}/ ..." that was commented out in the default file.
I added the HeaderProjectName as both run and build dependency in the client's package.xml.
Still on compiling I get error that no such file as "HeaderProjectName/HeaderFile.h".
What could be wrong or what am I missing?
Using catkin on Groovy.
Originally posted by r0nald on ROS Answers with karma: 268 on 2013-02-01
Comment by mirzashah on 2013-02-01:
what your'e describing sounds correct. try this: instead of running catkin_make, go into the build folder and run make VERBOSE=1. you'll be able to see the include paths that way and get us more info.
Comment by ayush_dewan on 2013-02-01:
Try adding project dependency in manifest.xml
Comment by r0nald on 2013-02-01:
When the cpp file (that needs the header from other project) is compiled, then my header's directory is not used.
Comment by mirzashah on 2013-02-05:
could you paste the output of the compile with verbose=1 out as well as your cmakelists.txt and package.xml for both projects? i don't have enough information right now
In the client package you need to find_package your 'HeaderProjectName', something like this will add the includes path from HeaderProjectName:
find_package(catkin REQUIRED COMPONENTS HeaderProjectName <other packages here>)
include_directories(${catkin_INCLUDE_DIRS})
An alternative method is that you can find_package HeaderProjectName directly:
find_package(HeaderProjectName REQUIRED)
include_directories(${HeaderProjectName_INCLUDE_DIRS})
Originally posted by WilliamWoodall with karma: 1626 on 2013-02-05
