hello everybody, I'm a newbie to ROS groovy as well as Ubuntu. I'm trying to follow up the ROS tutorials, and when I've com to this ROS/Tutorials/CreatingPackage when trying to find out the dependency of the package I've just created using command rospack depends1 Beginner std_msgs roscpp rospy which Beginner is my pack name, it showed the following error:
  File "/usr/lib/pymodules/python2.7/rosdep2/rospack.py", line 55, in init_rospack_interface
    lookup = _get_default_RosdepLookup(Options())
  File "/usr/lib/pymodules/python2.7/rosdep2/main.py", line 107, in _get_default_RosdepLookup
    verbose=options.verbose)
  File "/usr/lib/pymodules/python2.7/rosdep2/sources_list.py", line 501, in create_default
    sources = load_cached_sources_list(sources_cache_dir=sources_cache_dir, verbose=verbose)
  File "/usr/lib/pymodules/python2.7/rosdep2/sources_list.py", line 419, in load_cached_sources_list
    with open(cache_index, 'r') as f:
IOError: [Errno 13] Permission denied: '/home/edmond/.ros/rosdep/sources.cache/index'
[rospack] Error: could not call python function 'rosdep2.rospack.init_rospack_interface'
I think the problem goes with some python related files, but I've also tried not including rospy for my package, it remains the same error. Does anyone know what could possibly be the reason? Thanks a lot
EDIT: Forgot to mention, I'm using Ubuntu 12.04 right now
Originally posted by edmond320 on ROS Answers with karma: 61 on 2013-01-31
Comment by 130s on 2013-01-31:
Can you run $ dpkg -p ros-groovy-rospack and share the result? You can paste the result to your original question by click "Edit". Also, please always tell us which ROS distro (e.g. Groovy / Fuerte).
It seems you ran some command using sudo, which you should not have, and now you have read-protected files in '/home/edmond/.ros/rosdep/sources.cache/index'.
Remove all files in /home/edmond/.ros, using sudo if necessary. Then, don't use sudo commands anymore for any ros command. If you believe that a ros command only works with calling sudo, you are doing something wrong.
Originally posted by KruseT with karma: 7848 on 2013-02-01
Comment by satr on 2014-08-05:
I installed ros-groovy-ros-base for ARM on pcDuino and created package from tutorial http://wiki.ros.org/ROS/Tutorials/CreatingPackage. On error - commands: sudo chmod +R 777 ~/.ros/rosdep/sources.cache/index or deleting all from ~/.ros - did not help. Could you tell what else should I look at?
