All,
Is there a way I can launch a launch file on the master that runs rviz on my workstation?
If so, could you provide an example?
Thank you! Andy
Originally posted by Andrius on ROS Answers with karma: 41 on 2013-01-31
Comment by georgebrindeiro on 2013-01-31:
Could you clarify your question? From what I understood, you have two machines. Master is running on a machine that is not your workstation (a robot?). You want to be able to automatically run rviz on your workstation when you execute a launch file on the other machine. Is that right?
Comment by Andrius on 2013-01-31:
That is correct. Any thoughts on how to do this?
You should be able to do that with the <machine> tag.
Originally posted by joq with karma: 25443 on 2013-01-31
could you expound on that a bit? the machine tag seemed like a logical place to start, but i'm not sure of the syntax to remotely run rviz from my master to my workstation
Comment by georgebrindeiro on 2013-02-01:
Examples can be found here: http://www.ros.org/wiki/roslaunch/XML/machine#Examples Are there any tags you can't figure out?
