Hi all,
I would like to record a scene and save depth image + rgb image of the kinect sensor. therefore I use cv_bridge and save the images to png format. After that I want to use rgbdslam with my recorded data but it seems that I have a lot of data loss.
The color images are stored as 640×480 8-bit RGB images in PNG format.
The depth maps are stored as 640×480 16-bit monochrome images in PNG format.
But when I convert the images back to sensor_msgs::Image and display them with image_view the depth image looks totally different (much darker) as it looks when I directly display the depth image from the sensor.
Would be great to get your thoughts.
Originally posted by dinamex on ROS Answers with karma: 447 on 2013-01-29
Assuming 8UC3 rgb image, and 16UC1 depth image, this is what I use for saving and loading:
// save images
cv::imwrite("rgb.png",   rgb_img);
cv::imwrite("depth.png", depth_img);
// load images
rgb_img = cv::imread("rgb.png");
depth_img = cv::imread("depth.png", -1);
I believe the crucial part is the -1 flag. From the imread page:
flags: <0 Return the loaded image as is (with alpha channel).
Originally posted by Ivan Dryanovski with karma: 4954 on 2013-02-12
