So,
I have sensor_msgs::LaserScanPtr& scan_msg being passed in a function. the first line is BOOST::ASSERT(!scan_msg); the second line is BOOST::ASSERT(!scan_msg->ranges);
Problem: it has a compilation error : ! not defined for shared pointer so, I make a change BOOST::ASSERT(!scan_msg->ranges.get()) Now it has compilation error : get not defined for ranges .
What am I supposed to do to see if ranges is not empty ??? (I have considered operator precendence and applied all the parenthesis I could, to no avail).
~Cheers! navderm
Originally posted by navderm on ROS Answers with karma: 78 on 2013-01-25
The ranges field is just a std::vector. Try this:
if (scan_msg->ranges.empty()) { ... }
Originally posted by joq with karma: 25443 on 2013-01-25
