Hi all, I am not able to view the log file after a process dies (i.e. shows red color on screen)
[plan-2] process has died [pid 2803, exit code -11, cmd /home/plan __name:=plan __log:=/home/user/.ros/log/15dd5ecc-6520-11e2-b3cb-f0def116deab/plan-2.log]. log file: /home/user/.ros/log/15dd5ecc-6520-11e2-b3cb-f0def116deab/plan*.log
I cannot find plan.log in the location. However I can get the logs of roslaunch, rosout and rosmaster. Do I need to enable anything?
Cheers
Originally posted by aswin on ROS Answers with karma: 528 on 2013-01-22
Comment by kost9 on 2014-11-04:
Hi aswin, I am facing the exact same problem, My process dies, and the developer is asking for the log file, which I cannot find. Were you able to find that file? or how didi you debug?
It should be plan-2.log or anything like plan*.log.
It could also be that there is no log file if the segmentation fault happened before any logfile was written.
Originally posted by dornhege with karma: 31395 on 2013-01-23
Comment by aswin on 2013-01-23:
This may be the case since the fault happens within 5 seconds of launch.
Comment by aswin on 2013-01-31:
I have had several cases in which I do not have a log file. Currently I find out the fault by running ROS with GDB.
