Hello, everyone,
My goal: I would like to find a standard way to allow control loops to be developed separately from the CAN communication. This would allow for easy interfacing with the hand without considering the communication. If this seems impossible, or would take more work than it is worth, please advise.
Background: I am currently building a ROS stack to accompany a 16 DOF robotic hand sold by my company. Packages within currently handle CAN communication and provide some demo control code.
I would like to implement a CAN communication node which publishes raw data (in this case encoder values) and subscribes to torque commands.
In a separate node, I would like to implement a controller that subscribes to the encoder readings and publishes the control torque values. Currently I'm running into problems because the loops do not run at the exact same frequency (333.33Hz, off by about 0.1Hz max).
I am new to ROS, so I have not yet learned some of the more sophisticated practices.
Thank you for your support.
Originally posted by alexalspach on ROS Answers with karma: 11 on 2013-01-20
Actually I am not sure if ROS supports that use case. You could/should try implementing both nodes as nodelets at least, so that you avoid having separate binaries to communicate.
ROS adds queuing/ etc. in between which even if it works in testing, might not give you any guarantees. ROS aims more for asynchronous behaviour. You might need to just do it manually without ROS in between.
Originally posted by dornhege with karma: 31395 on 2013-01-21
