Hello, My name is Daniel Holanda. I'm a beginner using ROS and I have a problem that might be simple to solve. I'm trying to install pocketsphinx using the tutorial at pirobot.org/blog/0022/ When I type "rosmake --rosdep-install pocketsphinx" I have the following problem:
[ rosmake ] Packages requested are: ['pocketsphinx']
[ rosmake ] Logging to directory/home/daniel/.ros/rosmake/rosmake_output-20130117-180252 [ rosmake ] Expanded args ['pocketsphinx'] to: []
[ rosmake ] WARNING: The following args could not be parsed as stacks or packages: ['pocketsphinx'] [ rosmake ] ERROR: No arguments could be parsed into valid package or stack names.
I'm using Ubuntu 11.10 Gnome and Ros Electric.
Thank you for the help,
Dan
Originally posted by danielhn1992 on ROS Answers with karma: 1 on 2013-01-17
Hi, this is the same issue as this question, and strangely enough, the same exact package. ROS doesn't know where to look for the package you downloaded. You have to set the environment variable ROS_PACKAGE_PATH to tell it where to look. Read about environment variables here. Note that once you switch to the new ROS version, groovy, you won't have to do this.
Originally posted by thebyohazard with karma: 3562 on 2013-01-18
