I am simulating a wheeled robot of six-wheels and can be independently steered, like MER-Opportunity. The wheeled robot can perform throttling forward,
||---|| <--wheel orientation
crab-motion,
//---// <--wheel orientation when heading is 45
and turning on the spot.
//---\\ <--wheel orientation
My question is: Is it correct to say that I have 2 motion primitives? Throttling forward is basically crab-motion with heading zero.
  • $\begingroup$ hmm, I suppose it depends if orientation is important... $\endgroup$ Oct 15, 2014 at 9:00
  • $\begingroup$ Well, orientation is important. $\endgroup$
    – ikel
    Oct 16, 2014 at 9:50
While I am not really sure what you exactly mean by "motion primitive", having the ability to do the "crab-motion" enables you to translate regardless of your orientation and without changing it (assuming 180 degrees of steering) which would not be the case if you had only one pair of steerable wheels (like in cars, remember the parallel parking problem).
Note however that this is still non-holomonic motion system unless the wheels are omniwheels (you cannot rotate and translate independently).
  • $\begingroup$ Motion primitive (link) in the sense of a small action that a platform is able to perform. Normally, a complex motion is not suitable to solve all problems, rigid. Motion primitives can be used in series of execution to produce a complex motion to solve a problem. Hmm, I'm not sure if I explained it correctly. $\endgroup$
    – ikel
    Oct 16, 2014 at 9:54
    $\begingroup$ Then I guess it depends on the question, is your platform oriented (in sense that it has front and back, regardless of current wheels orientation) or not. If it's not then I'd say you have 2 motion primitives. If it is oriented (because for example you have some camera at the front or something) then I'd say you have 3 motion primitives (rotate wheels, rotate robot, translate in the direction of wheels). $\endgroup$ Oct 16, 2014 at 15:05
  • $\begingroup$ Voted as best answer as you made mention about non-holomonic moation system and platform oriented, which helped a lot. $\endgroup$
    – ikel
    Oct 17, 2014 at 19:12
