In this momment I only know a cpp API for Arduino/AVR. Do you know other existing cases?
It is planned to support more microcontrollers?
Originally posted by Pablo Iñigo Blasco on ROS Answers with karma: 2982 on 2013-01-17
rosserial is not tied explicitly to Arduino/AVR, but is instead a serial protocol that could be used with any embedded-scale device.
I believe that it was intended to be easily portable to embedded devices with a C++ compiler.
Something else that may be of interest to you is rosserial_embeddedlinux, which uses the same rosserial protocol to communicate with embedded linux devices. The author writes:
This package contains embedded-linux-specific extensions required to run rosserial on a small embedded linux system such as the VEXPro controller, Chumby alarm clock, WRT54GL router, Raspberry Pi, or many similar devices.
If you are interested in contributing to the longer-term embedded device goals of the ROS community, I encourage you to check out the ROS Embedded SIG.
Originally posted by mjcarroll with karma: 6414 on 2013-01-17
Comment by Pablo Iñigo Blasco on 2013-01-17:
Thanks. Pretty cool. Specially this is what I was looking for. That stack doc has changed substantialy since I last visited it.
