Hello all,
I am trying to run the URDF tutorial "Using urdf with robot_state_publisher". I have followed the instructions in the tutorial however, when I go to run rviz and pick /odom as my fixed frame I get an error that says "No transform from [ ] to [/odom]" within the RobotModel in rviz. Moreover, when I pick a different fixed frame I can see the model but it looks really strange (not like R2D2 at all). Is there something wrong I am doing here? Does anyone else get the same errors?
Kind Regards, Martin
Originally posted by MartinW on ROS Answers with karma: 464 on 2013-01-16
Comment by David Lu on 2013-01-16:
Are there tfs being published?
Comment by MartinW on 2013-01-16:
How can I check if there are? rxgraph says there are tf publications but it just says /tf [tf/tfMessage]
Add a TF tree to rviz?
Comment by MartinW on 2013-01-17:
Hey David, I'm not sure if I know what you mean? Here is a link to my rviz when I run the program. To my knowledge I have added a TF to rviz http://i.imgur.com/3SNpC.png
From my understanding it looks like there is no transform from /base_link to the /axis link. So either the model.xml file can be changed to replace the axis link with base_link or just add another joint that has base_link as the parent and axis as the child. I tried the first way and it worked
Comment by David Lu on 2013-01-17:
I can't reproduce your error in my copy of fuerte. You shouldn't have to name it base_link for it to work.
Is line 22 of the state_publisher copied correctly? I.e. does it say base_link or odom?
Originally posted by David Lu with karma: 10932 on 2013-01-17
odom_trans.header.frame_id = "odom"; odom_trans.child_frame_id = "base_link"; Should this be changed to axis?
Yes. It should say axis.
Robot_state_publisher publishes all the tfs in the robot_model, i.e. starting from axis. If you change the fixed frame in rviz to axis, then you will see everything relative to this coordinate frame (i.e. robot will not move). We publish the additional transform from odom to axis to specify how
...the pose should change relative to some other point.
Ahh okay this makes sense now. So the program state_publisher has its own tf transform odom_trans? which is an object from geometry_msgs::TransformStamped where we define the transform with the translation and rotation stuff in the //update transform section of the program?
Indeed. That is the truth.
Thank you very much for the help, David! I'm slowly starting to understand, the basics.. haha! It's great to have a helpful and resourceful community like this! :)
Glad to hear it. Be sure to hit the check box marking this answer as correct.
