ROS Fuerte
PR2 Gazebo
I'm testing PR2 Interactive Object Detection. When I add try to add a plugin to Rviz,
the ObjectSegmentation plugin from object_segmentation_gui,
Rviz segfaults and dies (see backtrace below).
The segfault is almost identical if using stereo camera or Kinect, so you can ignore the line "withDisparityChecked".
Also, when I tick the box to enable "interactive" (object segmentation) mode, the pop-up doesn't load, because it's not working I guess...
Funny thing, this pop-up worked the first time I tested PR2 Interactive Object Detection... now I realize it's broken.
Does anyone have some suggestions please?
cheers,
David.
Segfault:
image description
Backtrace:
image description
Originally posted by dbworth on ROS Answers with karma: 1103 on 2013-01-15
The Interactive Object Segmentation plugin is highly experimental, research code. Unfortunately, we are not able to actively support this version.
The version here might be more promising:
http://ros.org/wiki/bosch_object_segmentation_gui
But you'd have to contact the authors for more details on its current status.
Originally posted by Matei Ciocarlie with karma: 586 on 2013-01-15
