Hi
I'm trying to test PR2 Interactive Object Detection. When you load it up in Rviz, there is a "Detect" button which calls the recognition_translator node (an optional install), but this node requires the object_recognition_server package.
With Fuerte, I can install the following packages:
ros-fuerte-object-recognition-capture
ros-fuerte-object-recognition-core
ros-fuerte-object-recognition-linemod
ros-fuerte-object-recognition-msgs
ros-fuerte-object-recognition-reconstruction
ros-fuerte-object-recognition-ros
ros-fuerte-object-recognition-tod
ros-fuerte-object-recognition-transparent-objects
But I had to get the server package from here:
https://github.com/wg-perception/ros-object_recognition
which also has the -core and -msgs packages, so it's probably not compatible.
I'm trying to load the server with this launch file:
<launch>
  <arg name="config_file" default="config_detection.table" />
  <node pkg="object_recognition_server" ns="/object_recognition" name="object_recognition_server" output="screen" type="server.py" args="-c $(find object_recognition_server)/conf/$(arg config_file)">
  </node>
</launch>
and this config file:
source1:
  type: ros_kinect
  rgb_frame_id: '/camera_rgb_optical_frame'
sink1:
  type: table_publisher
  package: 'tabletop'
pipeline1:
  method: 'tabletop_table'
  package: 'tabletop'
  submethod: ''
  sources: [source1]
  sinks: [sink1]
  parameters: {}
which produces this error:
rospy args stripped ['-c', '/home/user/ros_workspace/object_recognition/object_recognition_server/conf/config_detection.table']
  File "/home/user/ros_workspace/object_recognition/object_recognition_server/server.py", line 88, in <module>
    server = RecognitionServer(args)
  File "/home/user/ros_workspace/object_recognition/object_recognition_server/server.py", line 15, in __init__
    self.plasm = create_detection_plasm()
TypeError: create_detection_plasm() takes exactly 4 arguments (0 given)
[ INFO] [1358271985.462667749]: waitForService: Service [/tabletop_object_recognition] has not been advertised, waiting...
[object_recognition/object_recognition_server-3] process has died [pid 24531, exit code 1, cmd /home/user/ros_workspace/object_recognition/object_recognition_server/server.py -c /home/user/ros_workspace/object_recognition/object_recognition_server/conf/config_detection.table __name:=object_recognition_server __log:=/home/user/ros_.ros/log/e17fdb50-5f39-11e2-9490-1078d2868e5d/object_recognition-object_recognition_server-3.log].
log file: /home/user/ros_.ros/log/e17fdb50-5f39-11e2-9490-1078d2868e5d/object_recognition-object_recognition_server-3*.log
Please what am I missing here?
cheers,
David.
Originally posted by dbworth on ROS Answers with karma: 1103 on 2013-01-15
Anything Electric has been deleted: it was a big hack anyway.
Fuerte and Groovy have almost the same code so it works on both. What you are looking for is the actionlib server:
rosrun object_recognition_ros server.py -c /opt/ros/groovy/share/object_recognition_tabletop/conf/config_detection.tabletop_table
(I just released a tabletop package). Expect doc updates on that in the next few days.
We have indeed not synced our APIs in a while with the interactive_manipulation folks. We are working on that. Any help is welcome :)
Originally posted by Vincent Rabaud with karma: 1111 on 2013-01-23
Comment by dbworth on 2013-01-23:
Great, thanks @vincent-rabaud What needs to be done to sync those 2 systems?
