Hi,
I have point p, normal n and vector v, which is orthogonal to n. I want to compute the gripper Pose perpendicular with the normal and rotated based on v. In other words the resulting frame should have z axis perpendicular to n and x or y perpendicular to v. How can I compute the orientation quaternion?
Thanks
Originally posted by liborw on ROS Answers with karma: 801 on 2013-01-14
If I understand you correctly you want an orientation/a new coordinate frame that is perpendicular to n, and "directed with v" (but v is not necessarily perpendicular to n).
The easiest might be to create a rotation matrix. n is one entry. A second one can be derived by n cross v. This should make sure that this entry is perpendicular to n and directed from v. The third one should be the cross of the other two.
My guess is that n cross v should go to column 1 and n to column 2, but not guarantees.
Originally posted by dornhege with karma: 31395 on 2013-01-14
Comment by liborw on 2013-01-14:
The v is actually orthogonal to n, I have edited the question.
Comment by dornhege on 2013-01-14:
This should make it easier. If I'm not mistaken, just take n, v, n cross v to build the rotation matrix.
