Hi, I'm using stage and slam_gmapping. Frame hierarchy is: /map->/odom->/base_footprint->/base_link->/base_laser_link.
I need to do some operations with the occupancy grid and the laser scan, and I need the position of the robot wrt the map.
Whenever I ask for the robot position (using the tf_echo program, or in C++ using TransformListener), I'm unable to retrieve the transform base_link<->map.
The error is (when running: rosrun tf tf_echo base_link map): Exception thrown:Lookup would require extrapolation into the past. Requested time 4.400000000 but the earliest data is at time 1358007388.064145711, when looking up transform from frame [/map] to frame [/base_link]
or (if I swap source and target frames): Exception thrown:Unable to lookup transform, cache is empty, when looking up transform from frame [/base_link] to frame [/map]
HOWEVER, when individually looking up transforms map<->odom and odom<->base_link, both transformations are found! How can this be?
Originally posted by federico.ferri on ROS Answers with karma: 41 on 2013-01-12
Based on the error you get from rosrun tf tf_echo base_link map, I would guess that the odom<->map and base_link<->odom transforms are in different time epochs. That would explain why each transform seems to work but trying to concatenate them doesn't.
Can you verify that both the odom<->map and base_link<->odom transforms have similar timestamps (you may need to inspect the output of the /tf topic) or double check whatever node you have that is outputting base_link<->odom ?
Originally posted by Eric Perko with karma: 8406 on 2013-01-12
