I have a package that depends on rxtools which in turn depends on swig-wx. My package will not compile in Groovy since it says that swig-wx does not exist. Running rosdep check on my package results in "resource not found [swig-wx]", but ros-groovy-swig-wx is installed:
 $ rosdep resolve swig-wx
 #apt
 ros-groovy-swig-wx
Does this have to do with rxtools being deprecated in Groovy? Everything works fine in Fuerte.
Originally posted by Ola Ringdahl on ROS Answers with karma: 328 on 2013-01-11
Post score: 5
Comment by Dirk Thomas on 2013-05-10:
The deprecation tag in the package.xml is only informational and has no functional effect.
We have a similar problem.
Here is the error log for compiling cob_bringup:
fxm@sony-fxm:~/projects/groovy/care-o-bot/cob_robots/cob_bringup$ make
mkdir -p bin
cd build && cmake -Wdev -DCMAKE_TOOLCHAIN_FILE=/opt/ros/groovy/share/ros/core/rosbuild/rostoolchain.cmake  ..
[rosbuild] Building package cob_bringup
[rosbuild] Cached build flags older than manifests; calling rospack to get flags
Failed to invoke /opt/ros/groovy/bin/rospack cflags-only-I;--deps-only cob_bringup
Package swig-wx was not found in the pkg-config search path.
Perhaps you should add the directory containing `swig-wx.pc'
to the PKG_CONFIG_PATH environment variable
No package 'swig-wx' found
  File "/usr/lib/pymodules/python2.7/rosdep2/rospack.py", line 45, in call_pkg_config
    value = subprocess.check_output(['pkg-config', option, pkg_name])
  File "/usr/lib/python2.7/subprocess.py", line 544, in check_output
    raise CalledProcessError(retcode, cmd, output=output)
subprocess.CalledProcessError: Command '['pkg-config', '--cflags-only-I', 'swig-wx']' returned non-zero exit status 1
[rospack] Error: could not call python function 'rosdep2.rospack.call_pkg_config'
CMake Error at /opt/ros/groovy/share/ros/core/rosbuild/public.cmake:129 (message):
  Failed to invoke rospack to get compile flags for package 'cob_bringup'.
  Look above for errors from rospack itself.  Aborting.  Please fix the
  broken dependency!
  /opt/ros/groovy/share/ros/core/rosbuild/public.cmake:227 (rosbuild_invoke_rospack)
  CMakeLists.txt:16 (rosbuild_init)
make: *** [all] Error 1
We were able to build and run our simulation after commenting the swig-wx related lines in /opt/ros/groovy/share/rxtools/package.xml. However, manipulating read-only files can't be the final solution...
Any suggestions? Thank you!
Originally posted by Felix Messmer with karma: 198 on 2013-03-13
