I am new to Morse and robotics.
This code control the robot by giving the linear and angular velocity.
This is the scene description
from morse.builder import *
robot = ATRV()
motion = MotionVW()
motion.add_stream('socket')
robot.append(motion)
semanticL = SemanticCamera()
semanticL.translate(x=0.2, y=0.3, z=0.9)
robot.append(semanticL)
semanticR = SemanticCamera()
semanticR.translate(x=0.2, y=-0.3, z=0.9)
robot.append(semanticR)
semanticL.add_stream('socket')
semanticR.add_stream('socket')
env = Environment('land-1/trees')
env.set_camera_location([10.0, -10.0, 10.0])
env.set_camera_rotation([1.0470, 0, 0.7854])
and this is the control script
import pymorse
with pymorse.Morse() as simu:
    simu.robot.motion.publish({"v": 3, "w": -1})
The robot moves well. But when I remove the semantic cameras from the scene description the robot do not move. I am confused, they are just sensor, why the robot don't move ?
  • $\begingroup$ I reposted the question on github.com/morse-simulator/morse/issues/567 $\endgroup$
    – djou
    Oct 11 '14 at 21:05
  • $\begingroup$ What is the behavior you are expecting? $\endgroup$
    – Ian
    Oct 14 '14 at 22:35
  • $\begingroup$ move from point x to y by changing linear and angular velocity $\endgroup$
    – djou
    Oct 15 '14 at 18:55
