I use ubuntu12.04 64 bits with ROS fuerte.
I follow BagRecordingPlayback tutorial.
I run:
  roslaunch openni_launch openni.launch depth_registration:=true
  optirun rosrun rviz rviz
I set the frame to /camera_link and add point cloud2 section to visualize /camera/depth_registered/points topic but get nothing.
I try to figure out what happened.
I follow several link of kinect problems, and I find some thread also have the similar situations.
I couldn't find an exact solvable solutions.
Can anyone help me step by step to solve this problem?
Thank you very much~
When I run:
  sam@sam:~$ rosrun image_view disparity_view image:=/camera/depth_registered/disparity
  Inconsistency detected by ld.so: dl-close.c: 759: _dl_close: Assertion `map->l_init_called' failed!
  sam@sam:~$
It shows the window with /camera/depth_registered/disparity title but no image on it.
I check the lib version without problems:
  sam@sam:~$ apt-cache policy libopenni-dev
  libopenni-dev:
    Installed: (none)
    Candidate: 1.5.4.0-3+precise1
    Version table:
       1.5.4.0-3+precise1 0
          500 http://packages.ros.org/ros/ubuntu/ precise/main amd64 Packages
  sam@sam:~$ apt-cache policy libopenni-sensor-primesense-dev
  libopenni-sensor-primesense-dev:
    Installed: (none)
    Candidate: 5.1.0.41-2+precise1
    Version table:
       5.1.0.41-2+precise1 0
  sam@sam:~$
My roslaunch output is this link.
When I run freenect, it shows:
  sam@sam:~$ roslaunch freenect_launch freenect-registered-xyzrgb.launch
  ... logging to /home/sam/.ros/log/92195ade-5b27-11e2-b007-e0b9a5f829db/roslaunch-sam-23199.log
  Press Ctrl-C to interrupt
  while processing /opt/ros/fuerte/stacks/freenect_stack/freenect_launch/launch/freenect.launch:
  while processing /opt/ros/fuerte/stacks/freenect_stack/freenect_launch/launch/examples/include/produce-xyzrgb.launch:
  Invalid roslaunch XML syntax: [Errno 2] No such file or directory: u'/opt/ros/fuerte/stacks/freenect_stack/freenect_launch/launch/examples/include/produce-xyzrgb.launch'
  sam@sam:~$
What happened?
========================== Before plugin kinect on usb port 2.0:
  sam@sam:~$ lsusb
  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
  Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
  Bus 003 Device 003: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
  Bus 001 Device 005: ID 13d3:3362 IMC Networks
  Bus 001 Device 004: ID 13d3:5710 IMC Networks
  Bus 003 Device 004: ID 046d:c077 Logitech, Inc.
  sam@sam:~$
After plugin kinect on usb port 2.0:
  sam@sam:~$ lsusb
  Bus 003 Device 005: ID 0409:005a NEC Corp. HighSpeed Hub
  Bus 003 Device 006: ID 045e:02b0 Microsoft Corp. Xbox NUI Motor
  Bus 003 Device 007: ID 045e:02ad Microsoft Corp. Xbox NUI Audio
  Bus 003 Device 008: ID 045e:02ae Microsoft Corp. Xbox NUI Camera
  sam@sam:~$
Originally posted by sam on ROS Answers with karma: 2570 on 2013-01-09
Comment by yigit on 2013-01-09:
Can you try this? rosrun image_view disparity_view image:=/camera/depth_registered/disparity
Comment by piyushk on 2013-01-11:
@sam: I've noticed 2 problems: First: You don't have the correct openni-packages installed. Notice when you run apt-cache policy it says none in front of installed. Second, you need to upgrade freenect_stack. The issue you've experienced has been fixed and updated debs released.
@sam: once you have the packages installed, installed should show the same thing as candidate.
I suspect you may have tried these already, but I've detailed all the problems I have faced in the past:
  • Your device may be plugged into a USB 3.0 port. If you only have USB 3.0 ports, see @MichaelH's answer in this thread
  • You may be using the older openni drivers. Check if you have the system packages libopenni-dev (v1.5.4) and libopenni-sensor-primesense-dev (v5.1.0) installed. If not, see @tfoote's email on how to upgrade here
Other things that might help solve the issue:
  • Output of your roslaunch command. It might be able to tell us if the openni driver did not load successfully
  • Does it work with depth_registered set to false?
  • As @yygyt suggested, can you view any of the images? Try viewing /camera/rgb/image_color and /camera/depth/image_raw in rviz or image_view.
  • Does the freenect based driver work? Try running the freenect-registered-xyzrgb.launch file
Originally posted by piyushk with karma: 2871 on 2013-01-10
Comment by yigit on 2013-01-10:
I once had problems with the depth-registration option of the old openni driver. I haven't had a chance to try the latest release though. @sam you may want to check out my experience http://answers.ros.org/question/46066/kinect-dynamic-reconfigure-does-not-work/#46450
Comment by sam on 2013-01-10:
/camera/rgb/image_color and /camera/depth/image_raw are both show nothing in rviz.
I have tried hg clone openni_launch and openni_camera and rosmake successfully, but it's not work also.
Comment by piyushk on 2013-01-10:
@sam If none of the recommendations work, try posting the output of lsusb and dmesg a few seconds after you plugin your kinect.
@sam and what about depth_registered topics (e.g. /camera/depth_registered/disparity). I think you forgot to mention them
Comment by sam on 2013-01-11:
I have edit my original post. And /camera/depth_registered/disparity is already have. It shows 'Inconsistency detected by ld.so: dl-close.c: 759: _dl_close: Assertion `map->l_init_called' failed!'. What can I do now? Thank you~
Comment by georgebrindeiro on 2013-01-11:
Have you tried using it without depth registration? I had issues with that here as well.
@sam: see my latest comment attached to your question.
