I am building a Hobby-weight robot and my weapon of choice is a spinning disk at the front.
As regards the disk I was thinking of buying commercial (grinder-type) disks and change type of disk depending on the "enemy's" chassis construction material. So for instance I would have an aluminum cutting disk if the enemy's chassis is made of aluminum and so on.
First question is therefore; do such disks do the job in practise (or break, fail to cut?)
Secondly, should I use a brushed or brush-less motor for the disk? I actually have ESCs for both but sort of feel a brushed motor will give me more torque while a brush-less motor might give me more speed. So which is more important speed or torque?
I do know - from my uncle who uses metal lathes - that machines that cut metal usually spin at a slower speed (drills, cutting wheels etc)- indeed he likes to say that metal working machines are safer than wood-working ones partially for this reason.
But I am a newbie and really would like to have an effective weapon if possible and breaking or not-cutting disks do not make such a weapon!
Also is it normal practise to use one battery for everything (drive and weapon) or have two separate batteries?
