Hi everyone,
I am trying to install RoboEarth within ROS Fuerte in Ubuntu 12.04. I looked over all answers concerning roboearth installation errors but found nothing like this. My installation fails when building the last package, namely re_comm. Can anyone help me? This is the relevant output:
[rosmake-0] Finished >> re_comm [ make ]
[ rosmake ] Last 40 lines_comm: 403.8 sec ]        [ 1 Active 102/103 Complete ]
                    CommunicationVisApplet.visualizeCommunication("", "Export of model for Cop ID "+req.object_id+" failed.", null, null);
  /home/asimo/ros/stacks/roboearth/re_comm/src/roboearth/wp1/UnizarRoboEarthInterface.java:437: cannot find symbol
  symbol  : variable CommunicationVisApplet
  location: class roboearth.wp1.UnizarRoboEarthInterface.RetrieveCopModelCallback
                    CommunicationVisApplet.visualizeCommunication("Requesting model for object '"+req.object_name+"' from RoboEarth...", "", null, "roboearth.png");
  /home/asimo/ros/stacks/roboearth/re_comm/src/roboearth/wp1/UnizarRoboEarthInterface.java:460: cannot find symbol
                        CommunicationVisApplet.visualizeCommunication("", "Object model download finished.\n\n"+targetFolderFile.getName(), null, null);
  /home/asimo/ros/stacks/roboearth/re_comm/src/roboearth/wp1/UnizarRoboEarthInterface.java:513: cannot find symbol
                            CommunicationVisApplet.visualizeCommunication("Sending model for object '"+req.object_name+"' to the vision system...\n\n"+xmlFileName, "", null, "cop.png");
  /home/asimo/ros/stacks/roboearth/re_comm/src/roboearth/wp1/UnizarRoboEarthInterface.java:523: cannot find symbol
                            CommunicationVisApplet.visualizeCommunication("", "Object model "+xmlFileName+" received.", null, null);
  /home/asimo/ros/stacks/roboearth/re_comm/src/roboearth/wp1/UnizarRoboEarthInterface.java:536: cannot find symbol
                        CommunicationVisApplet.visualizeCommunication("", "No model for "+req.object_name+" found.", null, null);
  /home/asimo/ros/stacks/roboearth/re_comm/src/roboearth/wp1/UnizarRoboEarthInterface.java:548: cannot find symbol
  42 errors
  make[3]: *** [../bin/roboearth/wp5/CopRoboEarthInterface.class] Error 1
  make[3]: Leaving directory `/home/asimo/ros/stacks/roboearth/re_comm/build'
  make[2]: *** [CMakeFiles/_java_compile_1_68.dir/all] Error 2
  make[2]: Leaving directory `/home/asimo/ros/stacks/roboearth/re_comm/build'
  make[1]: *** [all] Error 2
  make[1]: Leaving directory `/home/asimo/ros/stacks/roboearth/re_comm/build'
[ rosmake ] Output from build of package re_comm written to:
[ rosmake ]    /home/asimo/.ros/rosmake/rosmake_output-20130108-200745/re_comm/build_output.log
Thanks in advance!
Originally posted by georgebrindeiro on ROS Answers with karma: 1264 on 2013-01-08
As mentioned in another answer, it seems like its due to some refactoring in KnowRob.
So after you checkout the latest source code into your ROS_PACKAGE_PATH as described by @mortiz.
(I have not checked if this would work without the new package... you may try replacing the import line first before attempting to pull in knew knowrob)
svn co http://code.in.tum.de/pubsvn/knowrob/tags/latest knowrob
Replace the following import line with the one below it in the files which are causing this problem:
import de.tum.in.fipm.kipm.gui.visualisation.applets.CommunicationVisApplet; //delete
import edu.tum.cs.ias.knowrob.vis.applets.CommunicationVisApplet; //add
/roboearth/re_comm/src/roboearth/wp5/CopRoboEarthInterface.java
/roboearth/re_comm/src/roboearth/wp5/REClients.java
Originally posted by alexiip with karma: 71 on 2013-02-17
This is related to a refactoring in the KnowRob stack that changed some namespaces. You may need to install KnowRob from source by checking it out somewhere into your ROS_PACKAGE_PATH:
Otherwise you can also just comment out those lines where 'CommunicationVisApplet' appears.
Originally posted by moritz with karma: 2673 on 2013-01-29
Comment by alexiip on 2013-02-17:
Pulling new code did not seem to fix it. I guess commenting out is the only way.
