I am new in using catkin, as a former rosbuild user. I was following the new tutorials online. After I learning how to build a package, on website:
BuildingPackages
After I modify the package.xml in the created package, and source the setup.bash in installation directory, the output of catkin_make is :
Base path: /home/wu/catkin_ws
Source space: /home/wu/catkin_ws/src
Build space: /home/wu/catkin_ws/build
Devel space: /home/wu/catkin_ws/devel
Install space: /home/wu/catkin_ws/install
#### Running command: "make cmake_check_build_system" in "/home/wu/catkin_ws/build"
#### Running command: "make -j4" in "/home/wu/catkin_ws/build"
and there is no build file of beginner_tutorials in the build/ directory.
However, on another website: using_a_workspace
I tried another command
catkin_make --force-cmake
since I have compiled the workspace after I made the directory followed by the website: InstallingandConfiguringROSEnvironment
I am wondering is it correct to add --force-cmake after the catkin_make command or the problem occurs because some other issues?
Thanks Kanzhi
Originally posted by Kanzhi Wu on ROS Answers with karma: 1 on 2013-01-07
Yes, this was a bug in catkin_make: https://github.com/ros/catkin/issues/290 should be fixed with next release of catkin.
Originally posted by KruseT with karma: 7848 on 2013-01-07
