I recently installed groovy and I am trying to configure my installation, I have sourced the setup.bash file however when trying to configure my catkin workspace gives me error. When I try catkin_make inside catkin_ws, I get the following error;
  File "/opt/ros/groovy/bin/catkin_make", line 19, in <module>
    from catkin.init_workspace import init_workspace
ImportError: No module named init_workspace
Any help folks ? If rosbuild was available on groovy - I guess I would have gladly used that.
Originally posted by Arkapravo on ROS Answers with karma: 1108 on 2013-01-02
Comment by Dirk Thomas on 2013-01-02:
By the way a lot of packages are still using rosbuild in groovy.
Comment by Arkapravo on 2013-01-02:
@Dirk Thomas So ! catkin is not essential for groovy -- I CAN use rosbuild ?
Comment by joq on 2013-01-03:
Yes, rosbuild works fine with groovy.
Comment by Arkapravo on 2013-01-03:
@joq Thank you !
You have likely another version of catkin on your PYTHONPATH i.e. from Fuerte. You should retry it from a "clean" shell without sourcing Fuerte before (or in your bashrc).
Originally posted by Dirk Thomas with karma: 16276 on 2013-01-02
@Dirk Thomas YES ! You are right -- I had sourced Morse into my ROS Fuerte using another PYTHONPATH -- I have rectified my .bashrc -- everything is cool now !!!!
