I would like to know if there is some method or trait class in (roscpp or another library) which allows getting the "associated stamped type" of a Type T. For instance
StampedType::type ::type
If it does not exist, IMO it should. Its a very interesting method to do generic programming in ROS.
BTW I've also missed message inheritance in ROS (but this is another issue where a lot of discussion it is possible)
Originally posted by Pablo Iñigo Blasco on ROS Answers with karma: 2982 on 2012-12-29
I don't know of any implementation of that method. It might make an interesting library to contribute. However there's no way to do it automatically as a stamped type is more of a convention, and not all messages have it.
In the tf datatypes you will find a Stamped<> templated datatype for each type of data supported.
Originally posted by tfoote with karma: 58457 on 2012-12-29
Comment by Pablo Iñigo Blasco on 2012-12-31:
Yep I understand. It's a pitty that Stamped<> is only for tf messages and the only allowed types are statically set. Moreover it forces you to use a tfBroadacaster instead a generic ros msg publisher.
In any case it would be possible if there would be a template mechanism to generate msgs stamped datatypes. In that case Stamped would be a rosmsg type. In such case all the StampedMsgTypes would be unnecessary. The method ros::Publisher::publish might accept T or Stamped
The header data could be filled explicitly or implicitly by the ros::Publisher. At the same time, a subscriber could use either T or Stamped . IMHO this could be possible maintaining the backwards compatibility.
The header data could be filled explicitly or implicitly by the ros::Publisher... I think that this could be possible maintaining the backwards compatibility. Using rosmsg infraestructure even would be possible to make compatible StampedPose with Stamped
