I start the publisher
  pub = nh.advertise<sensor_msgs::PointCloud2> ("projected_inliers", 1);
I run ransac using the cylinder model
pcl::ModelCoefficients::Ptr coefficients2 (new pcl::ModelCoefficients);
seg.segment (*inliers2, *coefficients2);
I print the coefficients fine to the terminal.
std::cerr << "Cylinder coefficients: " << *coefficients2 << std::endl;
pubCyl.publish (*coefficients2);
But I can't seem to publish the coefficients2 successfully. It doesn't throw any errors but when I run rostopic echo /Cylinder_coef it slows my computer down to a stall if I don't end it rather quickly... I'm not sure if this has to do with it being a pointer and it somehow breaks or if I'm missing something else.
Originally posted by ncr7 on ROS Answers with karma: 325 on 2012-12-27
So figured out a solution. Very simple mistake on my part, the ROS publisher needed a string so I just did the following,
std_msgs::String msg; std::stringstream ss; ss << *coefficients2; msg.data = ss.str(); pubCyl.publish(msg);
Originally posted by ncr7 with karma: 325 on 2012-12-28
