After I run the node "camera_calibration" like this:
rosrun camera_calibration cameracalibrator.py --size 8x6 --square 0.108 image:=/pgr_camera/image_raw camera:=/pgr_camera
it shows as below:
Waiting for service /pgr_camera/set_camera_info ...
OK
*** Added sample 1, p_x = 0.897, p_y = 0.349, p_size = 0.277, skew = 0.027
Segmentation fault
Is there any one who can tell me why?
I am using electric on Ubuntu 10.04.And when I run the node "camera_calibration",there is no checkerboard in front of the camera.
Originally posted by sven_007 on ROS Answers with karma: 49 on 2012-12-25
Comment by joq on 2012-12-26:
What device and camera driver are you running?
The resolution ratio is too large. The node worked after I reduced the resolution ratio.Maybe too much data result in the Segmentation fault.
Originally posted by sven_007 with karma: 49 on 2013-01-14
Comment by georgebrindeiro on 2013-01-14:
Just for the sake of completeness, could you add the resolution that used to SEGFAULT and the resolution that doesn't?
Comment by sven_007 on 2013-04-06:
1280960 lead to SEGFAULT ,and 640480 doesn't.
