I am trying to remap a camera stream from /camera to /camera1_ns in gazebo.
<launch>
  <!-- set use_sim_time flag -->
  <param name="/use_sim_time" value="true" />
  <!-- start gazebo with an empty plane -->
  <node name="gazebo" pkg="gazebo" type="gazebo" args="$(find gazebo_worlds)/worlds/empty.world" respawn="false" output="screen"/>
<!-- start gui -->
<node name="gazebo_gui" pkg="gazebo" type="gui" respawn="false" output="screen"/>
<!-- spawn model -->
 <node name="spawn_arm" pkg="gazebo" type="spawn_model" args="-file simple_arm.model -gazebo -model     simple_arm" respawn="false" output="screen" >
<!-- remapping topics -->
<remap from="/camera1_ns" to="/camera" />
</node>
</launch>
But there is no /camera1_ns listed with rostopic list. Is this approach correct or should it be done otherwise?
Originally posted by davinci on ROS Answers with karma: 2573 on 2012-12-21
Does it help to delete the leading '/' in the remapped names?
<remap from="camera" to="camera1_ns" />
EDIT: Maybe I got the names backwards from what you intended?
EDIT2: Move the remap from the arm_spawn node to the gazebo node.
Originally posted by joq with karma: 25443 on 2012-12-22
Comment by davinci on 2012-12-24:
Thanks for your response. But it does not work. I should be able to see a camera1_ns using rostopic list?
Comment by davinci on 2012-12-29:
I am indeed remapping camera to camera1_ns But still not getting it to work...no camera1_ns is appearing in rostopic list. Tried it in several ways. Is the position of the remap argument okay?
Comment by joq on 2012-12-29:
It is inside the spawn_arm node. Maybe you should move it to the gazebo node?
Comment by davinci on 2012-12-30:
Yes, that works! Thanks! Seemed illogical as the simulation doesn't know anything yet about camera's at that point, but it seems to be the correct way.
