It is easy to start two kinects separately on two different Terminals with the launch files for two kinects by editing the following kinect1 launch file
kinect2 launch file
I can able to launch two nodes of type openni_node(openni_camera pkg) from single launch file
And i want to do the same with the node of type nodelet(openni_launch pkg)
Spent 2 days with this but failed
Need clear insights on this stuff!!
Originally posted by ros_vino on ROS Answers with karma: 1 on 2012-12-18
Comment by dornhege on 2012-12-18:
You don't need to edit the args. As the name says they are arguments. You can just pass different args to the same launch file and you will get two different launches.
You can use one launch file which expects arguments that you have mentioned in the question as input. Then u can call the launch file twice with different arguments.
Originally posted by ayush_dewan with karma: 1610 on 2013-01-26
