I've followed this tutorial
When I tried to fill in the action goal of the type JointTrajectoryActionGoal, I didn't know what value shoud goal.goal.trajectory.points[i].velocities[i] and goal.goal.trajectory.points[i].time_from_start be, which belonged to trajectory_msgs/JointTrajectoryPoint.msg
I've tried several value and felt that time_from_start seemed to be related to the total execution time, but still got no idea about velocities, which tended to make the trajectory weird.
I would like to know what's the meaning behind these parameters and how to set it up properly. Thanks~
Originally posted by Albert K on ROS Answers with karma: 301 on 2012-12-16
Yes, the semantics of the joint trajectory messages is a little under-specified. Some pointers:
  • time_from_start is relative to trajectory.header.stamp; each trajectory point's time_from_start must be greater than the last
  • the velocities specify the joint velocities you would like the joints to have at that trajectory point
  • the velocities should be all 0 for the first and last trajectory point
  • you shouldn't execute such a "hand-crafted" trajectory directly on the robot; instead, run it through a properly set-up trajectory_filter pipeline first to make sure it's physically possible to reach the desired joint trajectories at the given time points
I think an example would be nice, so this is a trajectory generated and executed on the Katana robot arm. (Actually, this is the new FollowJointTrajectoryAction and not the old JointTrajectoryAction format, but they are almost identical).
I just noticed while writing this answer that this trajectory might not be an ideal example. The accelerations are all 0, which doesn't make sense; they should either be empty (saying that there are no desired accelerations, and the controller is free to choose) or be filled to sensible values. Seems to be a bug in my trajectory filtering pipeline. Anyway, here you go:
header:
  seq: 0
  stamp:
    secs: 1355824277
    nsecs: 243513013
  frame_id: ''
goal_id:
  stamp:
    secs: 1355824277
    nsecs: 243517830
goal:
  trajectory:
    header:
      seq: 0
      stamp:
        secs: 1355824277
        nsecs: 443477691
      frame_id: ''
    joint_names: ['katana_motor1_pan_joint', 'katana_motor2_lift_joint', 'katana_motor3_lift_joint', 'katana_motor4_lift_joint', 'katana_motor5_wrist_roll_joint']
        positions: [-2.9641690268167444, 2.13549384276445, -2.1556486321117725, -1.9719493470579683, -2.9318804356548496]
        velocities: [0.0, 0.0, 0.0, 0.0, 0.0]
        accelerations: [0.0, 0.0, 0.0, 0.0, 0.0]
        time_from_start:
          secs: 0
          nsecs: 0
        positions: [-2.9251733424342388, 2.13549384276445, -2.1556486321117725, -1.9719493470579683, -2.8933095299198217]
        velocities: [0.29930315443351097, 0.0, 0.0, -6.139114030773157e-19, 0.2960428554763487]
        time_from_start:
          secs: 0
          nsecs: 228646348
        positions: [-2.8849641701621285, 2.13549384276445, -2.1556486321117725, -1.9719493470579683, -2.853538354776994]
        velocities: [0.44598050148009644, 0.0, 0.0, 1.823853811086392e-18, 0.4411224512312072]
        time_from_start:
          secs: 0
          nsecs: 339639817
        positions: [-2.52736640929761, 2.13549384276445, -2.1556486321117725, -1.9719493470579683, -2.4998358940105807]
        velocities: [1.0028722191625212, 0.0, 0.0, -1.6240875412254114e-17, 0.9919479666049925]
        time_from_start:
          secs: 0
          nsecs: 800369305
        positions: [-2.2959492044755803, 2.13549384276445, -2.1556486321117725, -1.9719493470579683, -2.2709395088336946]
        velocities: [1.0910884747158898, 0.0, 0.0, 4.7121007739083667e-17, 1.0792032855236304]
        time_from_start:
          secs: 1
          nsecs: 20369305
        positions: [-2.1094083544721736, 2.13549384276445, -2.1556486321117725, -1.9719493470579683, -2.0864306418873473]
        velocities: [1.0870331216234024, 0.0, 0.0, -1.5451562371091847e-16, 1.0751921072527668]
        time_from_start:
          secs: 1
          nsecs: 190369305
        positions: [-1.9654064488044534, 2.13549384276445, -2.1556486321117725, -1.9719493470579683, -1.9439973440205225]
        velocities: [1.0735605072416647, 0.0, 0.0, 5.153091454187644e-16, 1.0618662495956706]
        time_from_start:
          secs: 1
          nsecs: 324259613
        positions: [-1.7266965336015323, 2.13549384276445, -2.1556486321117725, -1.971949347057968, -1.7078876877058584]
        velocities: [1.0955434012456187, 0.0, 0.0, 5.577067357268163e-16, 1.0836096846920393]
        time_from_start:
          secs: 1
          nsecs: 544259614
        positions: [-1.5618053834346186, 2.13549384276445, -2.1556486321117725, -1.971949347057968, -1.5447926911610177]
        velocities: [1.1002506664107818, 0.0, 0.0, -1.6280551286439496e-16, 1.0882656737798182]
        time_from_start:
          secs: 1
          nsecs: 694259614
        positions: [-1.352801108899281, 2.13549384276445, -2.1556486321117725, -1.971949347057968, -1.3380650929928186]
        velocities: [1.0995760502885568, 0.0, 0.0, 3.1423072274376064e-17, 1.087598406227786]
        time_from_start:
          secs: 1
          nsecs: 884388906
        positions: [-1.2428109699673853, 2.13549384276445, -2.1556486321117725, -1.971949347057968, -1.229273072857686]
        velocities: [1.099721341194797, 0.0, 0.0, -1.0271726233852743e-17, 1.0877421144851813]
        time_from_start:
          secs: 1
          nsecs: 984388907
        positions: [-1.0668126798340363, 2.13549384276445, -2.1556486321117725, -1.971949347057968, -1.0551919260396805]
        velocities: [1.101621901250425, 0.0, 0.0, 3.1360609511064693e-18, 1.0896219718055542]
        time_from_start:
          secs: 2
          nsecs: 144388907
        positions: [-0.8186363391284005, 2.13549384276445, -2.1556486321117725, -1.971949347057968, -0.8097189616694035]
        velocities: [1.0917942273591639, 0.0, 0.0, -6.310525555784859e-19, 1.079901350427656]
        time_from_start:
          secs: 2
          nsecs: 370054003
        positions: [-0.6872969356042933, 2.13549384276445, -2.1556486321117725, -1.971949347057968, -0.6798102337462729]
        velocities: [1.1073704870325298, 0.0, 0.0, 2.6560761706557022e-19, 1.0953079384406423]
        time_from_start:
          secs: 2
          nsecs: 490054004
        positions: [-0.10077700694030943, 2.13549384276445, -2.1556486321117725, -1.971949347057968, -0.09967924647315002]
        velocities: [0.6703568712225323, 0.0, 0.0, -4.289222110264426e-20, 0.663054696902626]
        time_from_start:
          secs: 3
          nsecs: 76996454
        positions: [-0.00012129289047690934, 2.13549384276445, -2.1556486321117725, -1.971949347057968, -0.00011997165119668348]
        time_from_start:
          secs: 3
          nsecs: 356996686
  path_tolerance: []
  goal_tolerance: []
  goal_time_tolerance:
    secs: 0
    nsecs: 0
Originally posted by Martin Günther with karma: 11816 on 2012-12-17
Post score: 7
Comment by Adolfo Rodriguez T on 2012-12-18:
Trajectory endpoints don't need to have zero vel/acc. This is especially so for the first point: if it has time_from_start>0, a spline will be traced from the current state (can also have nonzero vel/acc) in time_from_start sec. We use this a lot for online trajectory substitution.
Comment by Albert K on 2012-12-18:
Thank you very much~ I have two questions. Is time from start equals to the execution time? Can I deduce that accelerations term equals to the acceleration at that trajectory point?
Actually, I've tried trajectory filter and get problems : http://answers.ros.org/question/50611/trajectory-filter-response-with-nothing/
Why is that some of the time_from_start are the same as (not greater than) the last points in the example?
Trajectories with unspecified accelerations use cubic spline interpolation, hence have no acceleration continuity. Trajectories specifying accelerations use quintic splines and guarantee acceleration continuity. Setting them to zero at waypoints is a perfectly valid choice (and used in practice).
Total desired trajectory duration is the time_from_start of the last trajectory point. In the posted example all waypoint times are monotonically increasing, as expected. Note that durations consist of two fields: secs and nsecs, and although the secs field may be equal for two points, nsec is not.
Comment by Martin Günther on 2012-12-18:
Thanks for your helpful comments, Adolfo! I forgot about trajectory substitution and acceleration continuity; the Katana arm is more limited than the PR2's arms, so it cannot do either of them.
Comment by varunagrawal on 2016-02-01:
Hi, I am using FollowJointTrajectoryGoal to define trajectories for the UR5. Would you recommend FollowJointTrajectoryAction for it as well? I am using the ros-industrial/universal_robot package.
Also, I can't seem to make sense of the values of the positions and velocities. What are their units? Metres and m/sec? Also, how do I specify the velocity with which the UR should move? When I run the program, the UR just goes full speed to the goal point.
Comment by Martin Günther on 2016-02-05:
All units in ROS are SI units (m, m/s, m/s^2, ...).
