Is it possible to have two different nodes with an dynamic_reconfigure::Server sharing the same "resource name" in the rosgraph context? This would be interesting to share configurations between different nodes. If someone send a config update request, then both nodes would be configured simultaneusly.
Node1.cpp for process 1:
dynamic_reconfigure::Server server1(ros::NodeHandle("/shared/name"));
server1.setCallback(myP1Callback);
Node2.cpp for process 2:
dynamic_reconfigure::Server server2(ros::NodeHandle("/shared/name"));
server2.setCallback(myP2Callback);
Originally posted by Pablo Iñigo Blasco on ROS Answers with karma: 2982 on 2012-12-14
I don't think so.
They would both have to declare the same ROS service.
Originally posted by joq with karma: 25443 on 2012-12-14
Comment by Pablo Iñigo Blasco on 2012-12-14:
I had just tested it. It doesn't work. As you say they both shares a service named "set_update" (a point-to-point operation). One interesting point its that everything looks work,but only one receives the updates. In the end I'll have to use topics. I think this would be a desirable feature.
