I followed PR2PluggingIn doc.
For example, I have a runable launch file:
<launch>
<!-- Set params for sim -->
<param name="detect_wall_norm/sim" value="True" type="bool"/>
<param name="detect_outlet/sim" value="True" type="bool"/>
<param name="r_gripper_controller/gripper_action_node/stall_velocity_threshold" value="0.01" type="double"/>
<!-- Start PR and load the plug and outlet in the world -->
<include file="$(find pr2_plugs_gazebo_demo)/launch/pr2_plug_outlet.launch"/>
<!-- Start the plugs app -->
<include file="$(find pr2_plugs_actions)/launch/plug_actions.launch"/>
<!-- ik action -->
<node pkg="pr2_arm_move_ik" type="arm_ik" name="r_arm_ik" output="screen">
<param name="joint_trajectory_action" value="r_arm_controller/joint_trajectory_generator" />
<param name="arm" value="r" />
<param name="free_angle" value="2" />
<param name="search_discretization" value="0.01" />
<param name="ik_timeout" value="5.0" />
</node>
<!-- Trajectory generator -->
<node pkg="joint_trajectory_generator" type="joint_trajectory_generator" output="screen"
name="joint_trajectory_generator" ns="r_arm_controller" >
<param name="max_acc" value="2.0" />
<param name="max_vel" value="2.5" />
</node>
name="joint_trajectory_generator" ns="l_arm_controller" >
</node>
<!-- tuckarm action -->
<node pkg="pr2_tuck_arms_action" type="tuck_arms.py" name="tuck_arms_action" output="screen">
<param name="r_joint_trajectory_action" value="r_arm_controller/joint_trajectory_generator" />
<param name="l_joint_trajectory_action" value="l_arm_controller/joint_trajectory_generator" />
<param name="move_duration" value="0.0" />
</node>
</launch>
But when I add the following lines:
<!-- navstack -->
<include file="$(find pr2_2dnav)/pr2_2dnav.launch" />
I will get error when I running:
sam@sam:~/code/ros/temp$ optirun roslaunch ./t2.launch
... logging to /home/sam/.ros/log/68f97e50-42ad-11e2-8d06-e0b9a5f829db/roslaunch-sam-26744.log
Press Ctrl-C to interrupt
roslaunch file contains multiple nodes named [/r_arm_controller/joint_trajectory_generator].
Please check all <node> 'name' attributes to make sure they are unique.
Also check that $(anon id) use different ids.
How could that possible?
I try to trace pr2_2dnav.launch.
<launch>
<include file="$(find pr2_machine)/$(env ROBOT).machine" />
<include file="$(find pr2_navigation_global)/amcl_node.xml" />
<include file="$(find pr2_navigation_teleop)/teleop.xml" />
<include file="$(find pr2_navigation_perception)/lasers_and_filters.xml" />
<include file="$(find pr2_navigation_perception)/ground_plane.xml" />
<include file="$(find pr2_navigation_global)/move_base.xml" />
</launch>
It seems very normal.
I am confused what situation I met.
Is there anything I missing?
How to fix it?
Thank you~
Originally posted by sam on ROS Answers with karma: 2570 on 2012-12-09
