Hi everybody
I have a question regarding the tf transformation which is published by amcl. I'm working with a husky so i use the amcl_demo.launch file to start amcl.
image description
I build an tf tree for my lasescanner and the odometry of the robot.
image description
I'm using 2 static broadcaster for the transformations base_footprint->base_link->laser
robot_pose is publishing the transform odom -> base_footprint
My problem is: If i start amcl it is not publishing the transform from map->odom. I'm getting the warning "Waiting on transform from /base_link to /map to become available before running costmap, tf error:" So in my understanding amcl should provide the missing transform map->odom to finish the tf tree. So why is it waiting for a transform between base_link and map?
Hoping for some help
Originally posted by Tirgo on ROS Answers with karma: 66 on 2012-12-06
Comment by Oysster on 2020-08-09:
Hey Tirgo, i got the same problem. Would you like to tell how to solve the problem?
It is not obvious from your description how you are loading the prior map into amcl. Are you running a map server in conjunction with it?
Also, could you post the output of amcl? You can modify your launch file to say
 <node pkg=... type=... node=... output="screen">
or find the appropriate log file.
Originally posted by Ivan Dryanovski with karma: 4954 on 2012-12-06
