when I run the command "rosrun uvc_camera camera_node",it shows as below:
using default calibration URL
camera calibration URL: file:///home/sven/.ros/camera_info/camera.yaml Unable to open camera calibration file [/home/sven/.ros/camera_info/camera.yaml]
Camera calibration file /home/sven/.ros/camera_info/camera.yaml not found.
using default calibration URL camera calibration URL: file:///home/sven/.ros/camera_info/camera.yaml Unable to open camera calibration file [/home/sven/.ros/camera_info/camera.yaml]
opening /dev/video0 terminate called after throwing an instance of 'std::runtime_error' what(): couldn't open /dev/video0 Aborted
Is there anyone who can help me ?
Originally posted by sven_007 on ROS Answers with karma: 49 on 2012-12-01
This probably is a duplicate of this answer. An answer has been provided there. You should also be able to add yourself to the video group by typing
usermod -a -G video [YOUR_USER_NAME]
then logging out and back in.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2012-12-01
