Provided you have a high update rate LIDAR (or your robot travels relatively steady and slowly) you can try hector_mapping. As can be seen in the video on the linked page, that can work pretty well while using no odometry at all. So far I had pretty positive feedback by numerous people using it on robots without odometry. The "localization only" mode isn't implemented right now, but having localization through SLAM is probably better than not having localization at all :)
Alternatively you could also try to fake odometry for AMCL either by using the laser_scan_matcher, by using imu data and maybe also desired velocity commands. The latter essentially means generating odometry by converting your cmd_vel commands to fake measured data. This might or might not improve AMCL performance, depending on how closely your robot can follow the motion commands you provide.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2012-11-27
Post score: 4
Comment by dornhege on 2012-11-27:
Here comes the hugely overkill approach if you really need localization instead of SLAM: Use hector_mapping to produce the odometry transform and feed that into amcl.
Comment by Stefan Kohlbrecher on 2012-11-27:
Now that you talk about it, hector_mapping actually can write out odometry using the undocumented "pub_odometry" parameter, which leads to odometry getting published on the "scanmatch_odom" topic. Feeding that into robot_pose_ekf could work (never tested it though)
Comment by Martin Günther on 2012-11-27:
Hehe, "hugely overkill" describes it pretty accurately... nice to know that hector_mapping can do it, though!
+1 for the idea of using the desired velocities, and for suggesting hector_mapping
Comment by Astronaut on 2012-11-27:
so i can use hactor_mapping package , than publish odometry on that topic. And than feeding it into robot_pose_ekf. So I will use hector mapping and robot_pose_ekf instead of using IMU and AMCL? OR I understand wrong??
Im bit confuse now. So what is the difference between using hector mapping + AMCl and hector_mapping +robot_pose_ekf. I get a bit confuse. Can somebody explain to me, please?? Or should I post that as a new question??
And also Martin said to use robot_pose_ekf if I have access to the wheel encoders. But I already said that I do not have any encoders. I do not provide such type of odometry. All is laser based.
What you should try first is just hector_mapping, to get an idea of how well it works for your robot. What would also be possible is generating odometry using hector_mapping and feeding that into robot_pose_ekf along with your IMU data, which in turn generates fused odometry for AMCL.
Ok. Thanks. Is there any tutorial or example how to use robot_pose_ekf and IMU with AMCL??
Comment by Astronaut on 2012-12-02:
@ Stefan Kohlbrecher I do not understand you. If It is possible to get the odometry using hector mapping and feeding that into robot_pose_ekf along with your IMU data, why I need than ACL?? With EKF robot pose I will have my localization. Why in turn generates fused odometry for AMCL??
But Hector Mapping is already using a EKF in the navigation stack. Why to use is than again robot_pose_ekf ??
Comment by dornhege on 2012-12-02:
robot_pose_ekf does NOT do localization, it only fuses odometry/imu/etc. readings. Also hector_mapping does not use robot_pose_ekf internally (AFAIK). The point of putting odometry from hector_mapping into robot_pose_ekf is to fuse your IMU reading with that.
But looking at the published paper http://www.sim.informatik.tu-darmstadt.de/publ/download/2011_SSRR_KohlbrecherMeyerStrykKlingauf_Flexible_SLAM_System.pdf it is clear that navigation subsystem is based on EKF.
Comment by Astronaut on 2012-12-03:
But as in ROS wiki documentation said robot_pose_ekf implements an extended Kalman filter for determining the robot pose. That is what Im looking for. An accurate pose estimation as my amcl "jumps"
Comment by dornhege on 2012-12-03:
Sorry for getting confusing: There are two different things: hector_mapping and robot_pose_ekf. hector_mapping will provide SLAM (map + pose). robot_pose_ekf takes position estimates and applies an EKF to it. The difference is that hector_mapping uses laser scans for feedback.
This should give you way better estimates than just using robot_pose_ekf. Maybe it's best for you to just try hector_mapping now and if that works continue from that.
So hector mapping take as input laser scans and IMU and provide SLAM, The robot_pose_ekf takes as input also laser and IMU and provide with estimated robot pose. So Which approach gives accurate robot pose??As my problem is to estimate more accurate robot pose. What mean laser scans for feedback?
No, the robot_pose_ekf does NOT take laser. That is the difference between the two and the reason why hector_mapping should give you more consistent estimates.
So I do not see any reason to use robot_pose_ekf . Because my sensor package consit of laser, IMU and camera. I do not know if robot_pose_ekf can givemore consistent estimates fusing IMU and the camera ( visio2 package).
Well robot_pose_ekf claims to be able to fuse IMU and visual odometry. That should be a use case for you, but I never used that.
Im not clear with robot_pose_ekf . How will be build tha map than?robot_pose_ekf give the estimated pose but what about localization in the map?? How to provide with the map , to localize that estimated robot_pose_ekf pose in the map??
That is what amcl or other localization approaches are used for.
Comment by gleb on 2016-10-04:
Hi, I want to use amcl with odom from hector_mapping combined with imu_data, but I am not able to get it running. I get tf errors, since I am missing tf from map to odom and from odom to base_footprint. How can I feed hectors odom to robot_pose_ekf and make robot_pose_ekf work together with amcl?
