Hi All
I'm trying to embed a ROS Android application into my android device however I get the following errors
[2012-11-27 10:20:22 - Dex Loader] Unable to execute dex: Java heap space
[2012-11-27 10:20:22 - org.ros.android.android_tutorial_pubsub.MainActivity] Conversion to Dalvik format failed: Unable to execute dex: Java heap space
in the console output of eclipse.
The project is based off the android_tutorial_pubsub project with my own NodeMain incorporated into it.
My Project has all the JARs from the android_tutorial_pubsub/libs wrapped up into a user library (a solution on stack overflow which didn't fix the problem).
The org.ros.android_gingerbread_mr1. is included in the build path, as when I include it as a library under the project>>properties>>android i get a conflict between its JARs and the ones from android_tutorial_pubsub. So its included on project>>properties>>Java Build Path as a required Project. (allows the MainActivity to compile and doesn't conflict JARs.
I've also adjusted the eclipse.ini file Xss property to 1024 as suggested by some.
Anyone have any thoughts?
Originally posted by PeterMilani on ROS Answers with karma: 1493 on 2012-11-26
