Hello fellow ROSers. I have compiled Fuerte from sources on an ACME FoxG20 board running embedian 6 wheezy (armv5tejl platform). I am now attempting to compile the publisher/subscriber tutorial.
Everything appears to work, and it compiles fine. Problem is: I always get this error
[ERROR] [1353939756.715474051]: Exception thrown when deserializing message of length [164] from [/add_two_ints_server]: Buffer Overrun
The same code runs flawlessly on my computer. Whatever mixture of node topology I use, when any node (core, server, client... doesn't matter) is run on the ARM, I get this error. I suspect it may have something to do with the network buffers, but I can't believe such a stupid example can overflow the buffer.
I already enlarged all TCP related buffers, so this shouldn't be the problem. Where else should I look for a solution?
Followup.
doing a grep -lri "buffer overrun" in ros-underlay returns
roscpp_core/roscpp_serialization/src/serialization.cpp
This here gives the function name
throwStreamOverrun()
Doing another grep on this yields:
roscpp_core/roscpp_serialization/include/ros/serialization.h
Reading the serialization.h I did a grep on both ROSCPP_SERIALIZATION_DECL and StreamOverrunException whose result is
roscpp_core/roscpp_serialization/include/ros/roscpp_serialization_macros.h
roscpp_core/roscpp_serialization/include/ros/serialized_message.h
Since this is leading me nowhere I decide to grep on the first part of the error message "Exception thrown when..." and this gives
ros-underlay/ros_comm/clients/cpp/roscpp/src/libros/message_deserializer.cpp
try
    SubscriptionCallbackHelperDeserializeParams params;
    params.buffer = serialized_message_.message_start;
    params.length = serialized_message_.num_bytes - (serialized_message_.message_start - serialized_message_.buf.get());
    params.connection_header = connection_header_;
    msg_ = helper_->deserialize(params);
  catch (std::exception& e)
    ROS_ERROR("Exception thrown when deserializing message of length [%d] from [%s]: %s", (uint32_t)serialized_message_.num_bytes, (*connection_header_)["callerid"].c_str(), e.what());
So somehow the try fails. Now how do I debug this???
Originally posted by Claudio on ROS Answers with karma: 859 on 2012-11-26
I would guess that your ARM machine is configured to run big-endian. The ROS communication protocol uses little-endian on the wire and as far as I know, roscpp's seralizer doesn't account for running on a big-endian host.
Adding big-endian support to roscpp has been discussed.
But you can likely work around your problem by configuring your ARM machine to run as little-endian instead of big-endian. There's usually a way to do that.
Btw, I would expect rospy to work properly across mixed-endian machines as it's using Python's struct module to implement serialization.
Originally posted by Brian Gerkey with karma: 2916 on 2012-11-27
Comment by enodiesop on 2013-05-03:
I am the same error with same architecture (AT91SAM9G25) and same debian version. I have build ros-groovy myself. With "dpkg-architecture" I know that my machine is little-endian. So, how I can resolve this error? Claudio, you have answer?
Comment by dave.peacock on 2014-02-25:
Years later I run into the same problem, with ros-fuerte on an ARM host running squeeze. Host is little-endian, cross-compiled code says it is little endian. Saw some post on ros-users that mentioned sizeof int8 vs int32, maybe this is the problem. Can anyone shed light on what they found?
