Hello, i have a subscriber that reads the values of a flex sensor that rosserial_arduino is reading, and have another file with a publisher that writes values in a topic of the shadow hand i need to send the flex sensor values to shadow hand, the question is, can i create only one .cpp file with the subscriber and the publisher there?
already i have this two files:
Subscriber:
#include <ros/ros.h>
#include <std_msgs/Float32.h>
void indiceCallback(const std_msgs::Float32::ConstPtr& msg)
  ROS_INFO("Valor indice: [%f]", msg->data);
  ros::init(argc, argv, "indice");
  ros::NodeHandle n;
  ros::Subscriber sub = n.subscribe("indice", 500, indiceCallback);
  ros::spin();
  return 0;
Publisher file:
#include "ros/ros.h"
#include "std_msgs/Float64.h"
#include <sstream>
  ros::init(argc, argv, "prueba");
  ros::NodeHandle n;
  ros::Publisher pub = n.advertise<std_msgs::Float64>("/sh_ffj3_mixed_position_velocity_controller/command", 1000);
  ros::Rate loop_rate(10);
  int count = 0;
  while (ros::ok())
    std_msgs::Float64 msg;
    msg.data = 1.5;
    ROS_INFO("%f", msg.data);
    pub.publish(msg);
    ros::spinOnce();
    loop_rate.sleep();
    ++count;
  return 0;
As you can see the publisher file publish the data value, but there this value i change manually, i need to put there the value that i have reading in the subscriber.
Thank you a lot people!!
I already do this:
#include "std_msgs/Float32.h"
#include <sstream>
void indiceCallback(const std_msgs::Float64::ConstPtr& msg)
  ros::NodeHandle n;
  ros::spin();
  //ros::NodeHandle n;
  ros::Publisher pub = n.advertise<std_msgs::Float64>("/sh_ffj3_mixed_position_velocity_controller/command", 500);
  int count = 0;
  while (ros::ok())
    //msg.data
    pub.publish(msg);
    ros::spinOnce();
    loop_rate.sleep();
    ++count;
  return 0;
When i run everything the subscriber shows to me what is listening, now i need to deliver this vlues to the publisher because i need to send this values to other topic. and if i do
rostopic echo /sh_ffj3_mixed_position_velocity_controller/command
it shoot me:
WARNING: no messages received and simulated time is active.
Is /clock being published?
Any Idea??
///////////////////////////////////Edit
#include <sstream>
  ros::NodeHandle n;
  ros::spin();
  ros::spinOnce();
  int count = 0;
  while (ros::ok())
    //msg.data
    pub.publish(msg);
    ros::spinOnce();
    loop_rate.sleep();
    ++count;
  return 0;
EDIT///////////////////////////////////////////////////////////
the code is like that:
#include <sstream>
  ros::NodeHandle n;
  ros::Subscriber sub = n.subscribe("indice", 50, indiceCallback);
  ros::spinOnce();
  ros::Publisher pub = n.advertise<std_msgs::Float64>("/sh_ffj3_mixed_position_velocity_controller/command", 50);
  ros::spinOnce();
  int count = 0;
  while (ros::ok())
    pub.publish(msg);
    ros::spinOnce();
    loop_rate.sleep();
    ++count;
  return 0;
and the answer is this one in the subscriber:
[ INFO] [1353578951.046220587, 3717.177000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.082715746, 3717.376000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.145255323, 3717.676000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.191476017, 3717.875000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.238836307, 3718.075000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.285820644, 3718.275000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.351882145, 3718.578000000]: Valor indice: [-0.177515]
[ INFO] [1353578951.390390033, 3718.777000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.434999373, 3718.974000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.499188053, 3719.272000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.549386961, 3719.473000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.591178303, 3719.673000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.653046354, 3719.975000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.694743784, 3720.172000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.741287422, 3720.372000000]: Valor indice: [-0.157791]
[ INFO] [1353578951.798968939, 3720.681000000]: Valor indice: [-0.157791]
And the answer of the command
rostopic echo /sh_ffj3_mixed_position_vocity_controller/command
Is:
data: 0.0
data: 0.0
data: 0.0
data: 0.0
data: 0.0
data: 0.0
data: 0.0
data: 0.0
Now i need to deliver the subscribing data to the publisher...
//////////////////////////EDIT////////////////////////////////// I created a global variable:
#include <sstream>
std_msgs::Float64::ConstPtr mensaje;
  mensaje=msg;
  ros::init(argc, argv, "segunda");
  ros::NodeHandle n;
   /////SUSCRIPTOR/////
  //ros::spinOnce();
   /////PUBLICADOR/////
  ros::spinOnce();
  int count = 0;
  while (ros::ok())
    if(mensaje){
    pub.publish(mensaje);
    ros::spinOnce();
    loop_rate.sleep();
    ++count;
  return 0;
but when i run the program this happens:
jose@ubuntu:~/prueba$ rosrun prueba segunda
segunda: /usr/include/boost/smart_ptr/shared_ptr.hpp:412: boost::shared_ptr<T>::reference boost::shared_ptr<T>::operator*() const [with T = const std_msgs::Float64_<std::allocator<void> >, boost::shared_ptr<T>::reference = const std_msgs::Float64_<std::allocator<void> >&]: Assertion `px != 0' failed.
Abortado (`core' generado)
Originally posted by joseescobar60 on ROS Answers with karma: 172 on 2012-11-21
Comment by dornhege on 2012-11-21:
You only need the spinOnce in the main while loop.
Comment by joseescobar60 on 2012-11-22:
OK, it already works, but i need to take the value that i reading with the subscriber and deliver this value to the publisher, how can i do that??
Comment by Lorenz on 2012-11-22:
You added a a different question that is not really related to your original one. It's better to create a new question for that. In your case, the problem is that you are trying to access a pointer that hasn't been initialized yet in your main loop. Add an if(mensaje) { ... } around your publish.
Thank you everybody, the problem was solved, i did what Lorenz said, thank you!!
3 Answers 3
You are getting a warning that clock is not being published. This indicates that the parameter use_sim_time is set to true but there is no time source. This will cause your call to sleep to block forever and subscriber callbacks are not handled. Get rid of the parameter with
rosparam delete use_sim_time
or start a simulator to provide time.
Originally posted by Lorenz with karma: 22731 on 2012-11-21
Post score: 5
Comment by joseescobar60 on 2012-11-21:
i did it, but the response is that the warning don't appear and the terminal remains freeze:
Comment by Lorenz on 2012-11-21:
And don't call ros::init twice.
i let the code like is in the last edit, and the response is the same, subscriber shows to me what he is readieng but the publisher is dead
The call to ros::spin will block so your program will never enter the publish loop. Get rid of the call to ros::spin and only keep ros::spinOnce.
in the last edit i shows the answer....
Do you know how can i take the message that i'm reading and deliver that message to the publisher, i need the topic /sh_ffj3_mixed_position_velocity_controller/command take the message that i'm subscribing.
Either use a global variable (considered bad style) or use a class that contains your subscriber, publisher and the publish loop and use a member variable.
how can i create a global variable of the type Float64?
Just declare it on top-level, outside of any function.
i'm doing that like this Float64 message; but when i do the make it says that Float64 is not a type!
Lorenz, Sorry for the inconvenience i just did a edit in the question, i create the global variable but it gives me a problem..
Comment by dornhege on 2012-11-22:
It's the same error as before. You need to check that it is valid as @Lorenz said before with if(mensaje). Why did you remove that?
Thank you everybody, the problem was solved, i did what Lorenz said, thak you!!
Sure. Publisher and Subscriber in one node is a very common use case.
Originally posted by dornhege with karma: 31395 on 2012-11-21
how? Do you have any example??
Just copy the indiceCallback and subscribe line from your subscriber to your publisher node and that should be it.
that is already what i do, the indiceCallback outside of the main, and the subscriber inside of the main, but nothing happens
Comment by Farid on 2018-09-13:
who has given you 3 thumbs up with your ridiculous unhelpful answer?
Of course you can have a publisher and subscriber in the same node. The only thing to watch out for is that the publisher mustn't modify the message once it's published, because the subscriber will typically share the same message object (no copy).
Your code is fine, because you always create a new msg object each time you publish it, and never touch it after publishing.
