I'm working on my arduino mega 2560 trying to alocate a float values that a flex sensor gives to arduino, but when i try lo read the topic it don't runs, only gives to me this message when i run:
jose@ubuntu:~$ rosrun rosserial_python serial_node.py /dev/ttyACM1
[INFO] [WallTime: 1353426930.914839] ROS Serial Python Node
[INFO] [WallTime: 1353426930.917873] Connected on /dev/ttyACM1 at 57600 baud
[INFO] [WallTime: 1353426933.336893] Setup Publisher on angulos [std_msgs/Float32MultiArray]
[ERROR] [WallTime: 1353426945.920335] Lost sync with device, restarting...
[INFO] [WallTime: 1353426946.190745] Setup Publisher on angulos [std_msgs/Float32MultiArray]
[ERROR] [WallTime: 1353426960.920971] Lost sync with device, restarting...
[INFO] [WallTime: 1353426961.049990] Setup Publisher on angulos [std_msgs/Float32MultiArray]
[ERROR] [WallTime: 1353426975.923001] Lost sync with device, restarting...
[INFO] [WallTime: 1353426976.409013] Setup Publisher on angulos [std_msgs/Float32MultiArray]
[ERROR] [WallTime: 1353426990.927987] Lost sync with device, restarting...
[INFO] [WallTime: 1353426991.268148] Setup Publisher on angulos [std_msgs/Float32MultiArray]
[ERROR] [WallTime: 1353427005.932885] Lost sync with device, restarting...
[INFO] [WallTime: 1353427006.127405] Setup Publisher on angulos [std_msgs/Float32MultiArray]
code in arduino:
#include <ros.h>
#include <std_msgs/Float32MultiArray.h>
ros::NodeHandle nh;
std_msgs::Float32MultiArray angulos;
ros::Publisher angulos_pub("angulos", &angulos);
int findice=1;
int fcorazon=2;
int fanular=3;
int fmenique=4;
int fpulgar=0;
int vind = 0;//valor que sensa el flex sensor valor en bits
int vcor = 0;//valor que sensa el flex sensor valor en bits
int vanu = 0;//valor que sensa el flex sensor valor en bits
int vmen = 0;//valor que sensa el flex sensor valor en bits
int vpul = 0;//valor que sensa el flex sensor valor en bits
float radind;
float radcor;
float radanu;
float radmen;
void setup(){
nh.initNode();
angulos.layout.dim = (std_msgs::MultiArrayDimension *)
malloc(sizeof(std_msgs::MultiArrayDimension) * 1);
angulos.layout.dim[0].label = "angulos";
angulos.layout.dim[0].size = 4;
angulos.layout.dim[0].stride = 1*4;
angulos.layout.dim_length = 1;
angulos.layout.data_offset = 0;
angulos.data = (float *)malloc(sizeof(float)*4);
angulos.data_length = 4;
nh.advertise(angulos_pub);
void loop(){
vind =analogRead(findice);
vcor =analogRead(fcorazon);
vanu =analogRead(fanular);
vmen =analogRead(fmenique);
radind = ((445-(vind))/(50.7));
radcor = ((449.85-(vcor))/(55.41));
radanu = ((479.1-(vanu))/(56.56));
radmen = ((414.95-(vmen))/(95.76));
angulos.data[0]= radind;
angulos.data[1]= radcor;
angulos.data[2]= radanu;
angulos.data[3]= radmen;
angulos_pub.publish(&angulos);
nh.spinOnce();
delay(500);
Originally posted by joseescobar60 on ROS Answers with karma: 172 on 2012-11-20
