For my bachelors thesis I'm programming an iRobot Create using ROS Fuerte and the turtlebot_node package with Python.
The Problem is that ~cmd_vel_timeout is set to 0.6 Seconds by default and this is very annoying since I don't want to send it the same vector (if it hasn't changed) for moving every half second.
Using rosnode info turtlebot I've seen that there is a service called /turtlebot/set_parameters and I'd like to use this service in my Python program to change the value of ~cmd_vel_timeout.
So here is my problem:
Where is the service /turtlebot/set_parameters defined so I can use it with rospy.ServiceProxy(..)?
Originally posted by mind4z on ROS Answers with karma: 15 on 2012-11-20
You can find out where the service is defined using rosservice type <srv>.
Besides that, the setting of cmd_vel_timeout to 0.6s is very reasonable and in general should NOT be set very high. Resending the same velocity is the right thing to do! The reason for that is safety. If the control program crashes/is stopped, you don't want the robot continuing to go with the last set velocity. I'd highly recommend not changing that.
Originally posted by dornhege with karma: 31395 on 2012-11-20
