I need two state linear actuator. You can have a look at the picture to understand what I mean.
Don't care about the hand !
mit inform project
(source: robaid.com)
I need to electrically move the things like this squares up and down. Bidirectional linear actuators are needed. What is the cheapest and tiniest actuator (or sth else) that I can use to move this squares up and down. There are just two states ('up','down'). Don't care how much higher a square rises, when it is up.
    $\begingroup$ The question isn't clear. Presumably a user uses a finger to press a button. What is the "two state linear actuator" supposed to do? Also, what's the bigger picture? Ie, what is your overall goal? $\endgroup$ Sep 21, 2014 at 1:11
  • $\begingroup$ Updated the question $\endgroup$
    – gungor
    Oct 10, 2014 at 23:35
What you are looking for is called a solenoid.
  • $\begingroup$ Short and to teh point, Ian :-) $\endgroup$
    – Andrew
    Oct 23, 2014 at 10:13
The problem is simple if you are using a coil and a pin (solenoid) but the size (diameter) of the coil would be the limiting factor to how closely your pins could be nested. Pneumatics (pressure= up and vacuum = down) could also be used and achieve a tighter nesting. The valve configuration would be the limiting factor with pneumatics.
