Hi.
I'm going to start the 3d mapping project with rgbdslam and octomap. but I'm struggling with rgbdslam.
I installed rgbdslam from source(using rosinstall) and I wrote $ rosdep install rgbdslam
then it said,
ERROR: the following packages/stacks could not have their rosdep keys resolved to system dependencies: rgbdslam: Missing resource eigen ROS path [0]=/opt/ros/fuerte/share/ros ROS path [1]=/opt/ros/fuerte/share ROS path [2]=/opt/ros/fuerte/stacks
there are already many Q&A's about fuerte and eigen problems, but I couldn't solve my problems with them.
This link is the answer already suggested.
But in my case, the manifest.xml file of rgbdslam already contains instead of . Also, I edited my manifest.xml file and CMakeLists.txt as "http://ros.org/wiki/eigen" says, but it was of no use as well.
Here is my manifest.xml.
<package>
  <description brief="SLAM on RGBD Data">
    This package can be used to register the point clouds from RGBD sensors such as the kinect or stereo cameras.
    The rgbdslam node can be connected easily to an octomap_server node to create a memory-efficient 3D map.
  </description>
  <author>Felix Endres, Juergen Hess, Nikolas Engelhard</author>
  <license>GPL v3</license>
  <review status="unreviewed" notes=""/>
  <url>http://ros.org/wiki/rgbdslam</url>
  <depend package="tf"/>
  <depend package="pcl"/>
  <depend package="rospy"/>
  <depend package="roscpp"/>
  <depend package="rosbag"/>
  <depend package="pcl_ros"/>
  <!--depend package="opencv2"/-->
  <depend package="cv_bridge"/>
  <depend package="sensor_msgs"/>
  <!--depend package="openni_camera"/-->
  <!--depend package="octomap_server"/-->
  <!--depend package="octomap"/-->
  <depend package="geometry_msgs"/>
  <depend package="visualization_msgs"/>
  <rosdep name="libqt4-opengl-dev"/>
  <rosdep name="libqt4-dev"/>
  <rosdep name="libglew-dev"/>
  <rosdep name="libdevil-dev"/>
  <rosdep name="libgsl"/>
  <!--rosdep name="gl2ps"/-->
  <rosdep name="eigen"/>
  <rosdep name="libg2o"/>
  <export>
    <rosdoc config="rosdoc.yaml" />
    <nodelet plugin="${prefix}/nodelet_plugins.xml" />
    <cpp cflags="-I${prefix}/srv_gen/cpp"/>
<cpp cflags="&lt;code&gt;pkg-config --cflags eigen3&lt;/code&gt; -I${prefix}/include
&lt;code&gt;rosboost-cfg --cflags&lt;/code&gt;" lflags="-Wl,-rpath,${prefix}/lib -L${prefix}/lib -lplanning_models"/>
 </export>
</package>
And the eigen part of my CMakeLists.txt
# Eigen ####################
find_package(Eigen)
IF(Eigen_FOUND)
  include_directories(${EIGEN_INCLUDE_DIRS})
  add_definitions(${EIGEN_DEFINITIONS})
ELSE(Eigen_FOUND)
  MESSAGE("Eigen package was not found. This is OK FOR ROS ELECTRIC, bad for fuerte\n")
ENDIF(Eigen_FOUND)
Do you have any solutions about this?
Thanks in advance! :)
Originally posted by Oppenheim on ROS Answers with karma: 41 on 2012-11-14
Comment by dornhege on 2012-11-14:
Did you do sudo rosdep init and rosdep update at some point before?
Comment by Felix Endres on 2012-11-15:
What dornhege says. Is libeigen3-dev installed?
Hi dornhege, Felix. I solved my problem. It's the problem of code of pcl which was out of date, so i erased it and reinstall it, it worked. Thanks for your kind answer and upgrading my question to cleaner version :)
Originally posted by Oppenheim with karma: 41 on 2012-11-19
