Hi, I'm not familiar at ROS errors,, firstly , i installed Roboearth Stack using these four steps :
http://www.ros.org/wiki/roboearth
the result of that : I have the roboearth stack in Home/ros
i made a connection between this and ROS by opening bashrc file and typed "export ROS_PACKAGE_PATH=/opt/ros/fuerte/share:/opt/ros/fuerte/stacks:/home/ros"
and saved
i begin to run re_comm package in roboearth stack but itthrow an error
salma@salma-G31M-S2L:~$ rosrun re_comm run
[rospack] Error: stack/package re_comm not found
i don't know why ??? re_comm not in /opt/ros/fuerte/stacks but in /home/ros/roboearth
why not found ??
and this is the result of rosmake roboearth now
salma@salma-G31M-S2L:~$ rosmake roboearth
[ rosmake ] rosmake starting...
[ rosmake ] Packages requested are: ['roboearth']
[ rosmake ] Logging to directory /home/salma/.ros/rosmake/rosmake_output-20121111-201259
[ rosmake ] Expanded args ['roboearth'] to:
[ rosmake ] WARNING: The following args could not be parsed as stacks or packages: ['roboearth']
[ rosmake ] ERROR: No arguments could be parsed into valid package or stack names.
Originally posted by salma on ROS Answers with karma: 464 on 2012-11-11
Comment by salma on 2012-11-12:
@tbh ???? any help here ?
@Lorenz ???? any help here ?
Comment by Lorenz on 2012-11-12:
Please do not add my name just to enforce a notification email. I see your question and I will answer it if I know the answer and if I have time. Be aware that I'm giving support here in my free time and voluntarily.
Comment by thebyohazard on 2012-11-12:
Are you sure /home/ros is the correct directory for roboearth? In FHS (Filesystem Hierarchy Standard), the home directory ~/. is the same as /home/username/. /home/. is a different place. Since your username is salma, I'd guess that you should use /home/salma/ros instead of /home/ros
lorenz @
i didn't mean it :S ,, just i was reading ROS EnvironmentVariables and it was last updates by u !! so i mentioned u ,,,,, Not to enforce a notification email !! ,, thanks by the way :)
@tbh Ok I will try it and tell you the result ,, yesterday i decided to uninstall ROS and install it again after no one answered me ,, i 'm installing it again and 'll retry :) thanks very much
Comment by salma on 2012-11-13:
@tbh
it's okey it solved ,, thanks very much
Comment by thebyohazard on 2012-11-13:
Great! Be sure and post the answer or accept the right one for others who might have the same problem.
you should use /home/username/ros instead of /home/ros
Originally posted by salma with karma: 464 on 2012-11-13
