I am just starting with ROS. On a new Ubuntu 12.04 installation, i issued apt-get ros-fuerte-* and installed everything (except openni-dev that needs SSE3 and i have only SSE2).
Now i can't start gazebo!!
roslaunch gazebo_worlds empty_world.launch
... logging to /home/amh/.ros/log/348d8d28-2b9c-11e2-85c7-00166f6382d6/roslaunch-amh-Latitude-D610-17941.log
Press Ctrl-C to interrupt
started roslaunch server http://amh-Latitude-D610:57229/
SUMMARY
PARAMETERS
 * /rosdistro
 * /rosversion
 * /use_sim_time
NODES
    gazebo (gazebo/gazebo)
    gazebo_gui (gazebo/gui)
auto-starting new master
Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading' from '/usr/lib/python2.7/threading.pyc'> ignored
process[master]: started with pid [17957]
setting /run_id to 348d8d28-2b9c-11e2-85c7-00166f6382d6
process[rosout-1]: started with pid [17970]
started core service [/rosout]
process[gazebo-2]: started with pid [17984]
Gazebo multi-robot simulator, version 1.0.2
Copyright (C) 2011 Nate Koenig, John Hsu, Andrew Howard, and contributors.
Released under the Apache 2 License.
http://gazebosim.org
process[gazebo_gui-3]: started with pid [17991]
Msg Waiting for master
Msg Connected to gazebo master @ http://localhost:11345
Msg Waiting for master[ INFO] [1352596072.851921503]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[ INFO] [1352596074.145719550]: joint trajectory plugin missing <updateRate>, defaults to 0.0 (as fast as possible)
Illegal instruction (core dumped)
[gazebo-2] process has died [pid 17984, exit code 132, cmd /opt/ros/fuerte/stacks/simulator_gazebo/gazebo/scripts/gazebo /opt/ros/fuerte/stacks/simulator_gazebo/gazebo_worlds/worlds/empty.world __name:=gazebo __log:=/home/amh/.ros/log/348d8d28-2b9c-11e2-85c7-00166f6382d6/gazebo-2.log].
log file: /home/amh/.ros/log/348d8d28-2b9c-11e2-85c7-00166f6382d6/gazebo-2*.log
/opt/ros/fuerte/stacks/simulator_gazebo/gazebo/scripts/gui: line 2: 17994 Illegal instruction     (core dumped) `rospack find gazebo`/gazebo/bin/gzclient -g `rospack find gazebo`/lib/libgazebo_ros_paths_plugin.so
[gazebo_gui-3] process has died [pid 17991, exit code 132, cmd /opt/ros/fuerte/stacks/simulator_gazebo/gazebo/scripts/gui __name:=gazebo_gui __log:=/home/amh/.ros/log/348d8d28-2b9c-11e2-85c7-00166f6382d6/gazebo_gui-3.log].
log file: /home/amh/.ros/log/348d8d28-2b9c-11e2-85c7-00166f6382d6/gazebo_gui-3*.log
BTW, /opt/ros/fuerte/stacks/simulator_gazebo/CMakeLists.txt shows 1.6.16. I am confusing this with 1.0.2 (written in above log) and 1.2 on http://gazebosim.org !!
Please help me getting started with ROS.
Thanks
Update I am using Ubuntu 12.04 LTS. The output of lspci |grep VGA
00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 03)
In the details panel of system settings
Graphics: Intel® 915GM x86/MMX/SSE2
Experience: Standard
The cpu flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov clflush dts acpi mmx fxsr sse sse2 ss tm pbe nx up bts est tm2
Update 2 using "roslaunch gazebo_worlds empty_world_no_x.launch"
... logging to /home/amh/.ros/log/ea152620-2cf9-11e2-96c6-00166f6382d6/roslaunch-amh-Latitude-D610-30993.log
started roslaunch server http://localhost:44406/
SUMMARY
PARAMETERS
 * /rosdistro
 * /rosversion
 * /use_sim_time
NODES
process[master]: started with pid [31009]
setting /run_id to ea152620-2cf9-11e2-96c6-00166f6382d6
process[rosout-1]: started with pid [31022]
process[gazebo-2]: started with pid [31036]
[1;[ INFO] [1352746273.994021826]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
32mMsg Waiting for master
[ INFO] [1352746275.484051598]: joint trajectory plugin missing <updateRate>, defaults to 0.0 (as fast as possible)
[gazebo-2] process has died [pid 31036, exit code 132, cmd /opt/ros/fuerte/stacks/simulator_gazebo/gazebo/scripts/gazebo -r /opt/ros/fuerte/stacks/simulator_gazebo/gazebo_worlds/worlds/empty.world __name:=gazebo __log:=/home/amh/.ros/log/ea152620-2cf9-11e2-96c6-00166f6382d6/gazebo-2.log].
log file: /home/amh/.ros/log/ea152620-2cf9-11e2-96c6-00166f6382d6/gazebo-2*.log
Should roscore be already running before gazebo ? Trying it gives me at the end:
all processes on machine have died, roslaunch will exit
shutting down processing monitor...
... shutting down processing monitor complete
done
Update 3
rosmake gazebo_worlds
[ rosmake ] rosmake starting...
[ rosmake ] Packages requested are: ['gazebo_worlds']
[ rosmake ] Logging to directory /home/amh/.ros/rosmake/rosmake_output-20121113-090955
[ rosmake ] Expanded args ['gazebo_worlds'] to:
['gazebo_worlds']
[rosmake-0] Starting >>> rostest [ make ]
[rosmake-0] Finished <<< rostest  No Makefile in package rostest
[rosmake-0] Starting >>> rosbuild [ make ]
[rosmake-0] Finished <<< rosbuild  No Makefile in package rosbuild
[rosmake-0] Starting >>> xacro [ make ]
[rosmake-0] Finished <<< xacro ROS_NOBUILD in package xacro
[rosmake-0] Starting >>> ivcon [ make ]
[rosmake-0] Finished <<< ivcon ROS_NOBUILD in package ivcon
[rosmake-0] Starting >>> common_rosdeps [ make ]
[rosmake-0] Finished <<< common_rosdeps ROS_NOBUILD in package common_rosdeps
[rosmake-0] Starting >>> ogre [ make ]
[rosmake-0] Finished <<< ogre ROS_NOBUILD in package ogre
[rosmake-0] Starting >>> std_msgs [ make ]
[rosmake-0] Finished <<< std_msgs  No Makefile in package std_msgs
[rosmake-0] Starting >>> geometry_msgs [ make ]
[rosmake-0] Finished <<< geometry_msgs  No Makefile in package geometry_msgs
[rosmake-0] Starting >>> sensor_msgs [ make ]
[rosmake-0] Finished <<< sensor_msgs  No Makefile in package sensor_msgs
[rosmake-0] Starting >>> trajectory_msgs [ make ]
[rosmake-0] Finished <<< trajectory_msgs  No Makefile in package trajectory_msgs
[rosmake-0] Starting >>> gazebo_msgs [ make ]
[rosmake-0] Finished <<< gazebo_msgs ROS_NOBUILD in package gazebo_msgs
[rosmake-0] Starting >>> roslib [ make ]
[rosmake-0] Finished <<< roslib  No Makefile in package roslib
[rosmake-0] Starting >>> bullet [ make ]
[rosmake-0] Finished <<< bullet ROS_NOBUILD in package bullet
[rosmake-0] Starting >>> roslang [ make ]
[rosmake-0] Finished <<< roslang  No Makefile in package roslang
[rosmake-0] Starting >>> roscpp [ make ]
[rosmake-0] Finished <<< roscpp  No Makefile in package roscpp
[rosmake-0] Starting >>> colladadom [ make ]
[rosmake-0] Finished <<< colladadom ROS_NOBUILD in package colladadom
[rosmake-0] Starting >>> urdf_interface [ make ]
[rosmake-0] Finished <<< urdf_interface ROS_NOBUILD in package urdf_interface
[rosmake-0] Starting >>> urdf_parser [ make ]
[rosmake-0] Finished <<< urdf_parser ROS_NOBUILD in package urdf_parser
[rosmake-0] Starting >>> collada_parser [ make ]
[rosmake-0] Finished <<< collada_parser ROS_NOBUILD in package collada_parser
[rosmake-0] Starting >>> urdf [ make ]
[rosmake-0] Finished <<< urdf ROS_NOBUILD in package urdf
[rosmake-0] Starting >>> std_srvs [ make ]
[rosmake-0] Finished <<< std_srvs  No Makefile in package std_srvs
[rosmake-0] Starting >>> rosconsole [ make ]
[rosmake-0] Finished <<< rosconsole  No Makefile in package rosconsole
[rosmake-0] Starting >>> angles [ make ]
[rosmake-0] Finished <<< angles ROS_NOBUILD in package angles
[rosmake-0] Starting >>> rospy [ make ]
[rosmake-0] Finished <<< rospy  No Makefile in package rospy
[rosmake-0] Starting >>> roswtf [ make ]
[rosmake-0] Finished <<< roswtf  No Makefile in package roswtf
[rosmake-0] Starting >>> message_filters [ make ]
[rosmake-0] Finished <<< message_filters  No Makefile in package message_filters
[rosmake-0] Starting >>> tf [ make ]
[rosmake-0] Finished <<< tf ROS_NOBUILD in package tf
[rosmake-0] Starting >>> rosgraph_msgs [ make ]
[rosmake-0] Finished <<< rosgraph_msgs  No Makefile in package rosgraph_msgs
[rosmake-0] Starting >>> rosservice [ make ]
[rosmake-0] Finished <<< rosservice  No Makefile in package rosservice
[rosmake-0] Starting >>> dynamic_reconfigure [ make ]
[rosmake-0] Finished <<< dynamic_reconfigure ROS_NOBUILD in package dynamic_reconfigure
[rosmake-0] Starting >>> protobuf [ make ]
[rosmake-0] Finished <<< protobuf ROS_NOBUILD in package protobuf
[rosmake-0] Starting >>> gazebo [ make ]
[rosmake-0] Finished <<< gazebo ROS_NOBUILD in package gazebo
[rosmake-0] Starting >>> gazebo_tools [ make ]
[rosmake-0] Finished <<< gazebo_tools ROS_NOBUILD in package gazebo_tools
[rosmake-0] Starting >>> pluginlib [ make ]
[rosmake-0] Finished <<< pluginlib ROS_NOBUILD in package pluginlib
[rosmake-0] Starting >>> bond [ make ]
[rosmake-0] Finished <<< bond ROS_NOBUILD in package bond
[rosmake-0] Starting >>> smclib [ make ]
[rosmake-0] Finished <<< smclib ROS_NOBUILD in package smclib
[rosmake-0] Starting >>> bondcpp [ make ]
[rosmake-0] Finished <<< bondcpp ROS_NOBUILD in package bondcpp
[rosmake-0] Starting >>> nodelet [ make ]
[rosmake-0] Finished <<< nodelet ROS_NOBUILD in package nodelet
[rosmake-0] Starting >>> nav_msgs [ make ]
[rosmake-0] Finished <<< nav_msgs  No Makefile in package nav_msgs
[rosmake-0] Starting >>> diagnostic_msgs [ make ]
[rosmake-0] Finished <<< diagnostic_msgs  No Makefile in package diagnostic_msgs
[rosmake-0] Starting >>> diagnostic_updater [ make ]
[rosmake-0] Finished <<< diagnostic_updater ROS_NOBUILD in package diagnostic_updater
[rosmake-0] Starting >>> self_test [ make ]
[rosmake-0] Finished <<< self_test ROS_NOBUILD in package self_test
[rosmake-0] Starting >>> driver_base [ make ]
[rosmake-0] Finished <<< driver_base ROS_NOBUILD in package driver_base
[rosmake-0] Starting >>> rosbag [ make ]
[rosmake-0] Finished <<< rosbag  No Makefile in package rosbag
[rosmake-0] Starting >>> nodelet_topic_tools [ make ]
[rosmake-0] Finished <<< nodelet_topic_tools ROS_NOBUILD in package nodelet_topic_tools
[rosmake-0] Starting >>> pcl_ros [ make ]
[rosmake-0] Finished <<< pcl_ros ROS_NOBUILD in package pcl_ros
[rosmake-0] Starting >>> pcl [ make ]
[rosmake-0] Finished <<< pcl  No Makefile in package pcl
[rosmake-0] Starting >>> image_transport [ make ]
[rosmake-0] Finished <<< image_transport ROS_NOBUILD in package image_transport
[rosmake-0] Starting >>> gazebo_plugins [ make ]
[rosmake-0] Finished <<< gazebo_plugins ROS_NOBUILD in package gazebo_plugins
[rosmake-0] Starting >>> gazebo_worlds [ make ]
[rosmake-0] Finished <<< gazebo_worlds ROS_NOBUILD in package gazebo_worlds
[ rosmake ] Results:
[ rosmake ] Built 50 packages with 0 failures.
[ rosmake ] Summary output to directory
[ rosmake ] /home/amh/.ros/rosmake/rosmake_output-20121113-090955
amh@amh-Latitude-D610:~/fuerte_workspace$ roslaunch gazebo_worlds empty_world_no_x.launch
... logging to /home/amh/.ros/log/3d3efb0c-2d61-11e2-aba2-00166f6382d6/roslaunch-amh-Latitude-D610-32411.log
started roslaunch server http://localhost:37385/
SUMMARY
PARAMETERS
 * /rosdistro
 * /rosversion
 * /use_sim_time
NODES
process[master]: started with pid [32427]
setting /run_id to 3d3efb0c-2d61-11e2-aba2-00166f6382d6
process[rosout-1]: started with pid [32440]
process[gazebo-2]: started with pid [32454]
[ INFO] [1352790652.113045154]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[ INFO] [1352790653.894700277]: joint trajectory plugin missing <updateRate>, defaults to 0.0 (as fast as possible)
[gazebo-2] process has died [pid 32454, exit code 132, cmd /opt/ros/fuerte/stacks/simulator_gazebo/gazebo/scripts/gazebo -r /opt/ros/fuerte/stacks/simulator_gazebo/gazebo_worlds/worlds/empty.world __name:=gazebo __log:=/home/amh/.ros/log/3d3efb0c-2d61-11e2-aba2-00166f6382d6/gazebo-2.log].
log file: /home/amh/.ros/log/3d3efb0c-2d61-11e2-aba2-00166f6382d6/gazebo-2*.log
Originally posted by amh on ROS Answers with karma: 1 on 2012-11-10
Comment by SL Remy on 2012-11-11:
1.6.16 is the version of the simulator_gazebo (ROS) package.. it uses Gazebo 1.0.2 which is a standalone piece of code.
Can you edit your question and include some information? What operating system are you using? (e.g. Ubuntu Precise, Debian Squeeze, etc.). What is the result of lspci |grep VGA (what graphics card are you using)?
Comment by SL Remy on 2012-11-12:
Could you try roslaunch gazebo_worlds empty_world_no_x.launch
Comment by amh on 2012-11-12:
still the same error (Update 2)
@Amal Please check my Update 3
Comment by SL Remy on 2012-11-13:
@amh roslaunch starts a roscore if there isn't already one running
It seems that it truly may be the gazebo server that is segfaulting...
I'd suggest running roslaunch gazebo_worlds debug.launch and reporting the issue on Gazebo Trac
Originally posted by SL Remy with karma: 2022 on 2012-11-13
