i want my robot to do simple calculation like addition or subtraction on my voice command how to proceed ? :( the code that i am trying is as follow
#!/usr/bin/env python
import roslib; roslib.load_manifest('pi_speech_tutorial') import rospy
from time import gmtime, strftime from geometry_msgs.msg import Twist from std_msgs.msg import String from math import copysign import re
Small = { 'zero': 0, 'one': 1, 'two': 2, 'three': 3, 'four': 4, 'five': 5, 'six': 6, 'seven': 7, 'eight': 8, 'nine': 9, 'ten': 10, 'eleven': 11, 'twelve': 12, 'thirteen': 13, 'fourteen': 14, 'fifteen': 15, 'sixteen': 16, 'seventeen': 17, 'eighteen': 18, 'nineteen': 19, 'twenty': 20, 'thirty': 30, 'forty': 40, 'fifty': 50, 'sixty': 60, 'seventy': 70, 'eighty': 80, 'ninety': 90 }
Magnitude = { 'thousand': 1000, 'million': 1000000, 'billion': 1000000000, 'trillion': 1000000000000, 'quadrillion': 1000000000000000, 'quintillion': 1000000000000000000, 'sextillion': 1000000000000000000000, 'septillion': 1000000000000000000000000, 'octillion': 1000000000000000000000000000, 'nonillion': 1000000000000000000000000000000, 'decillion': 1000000000000000000000000000000000, }
class TalkBack:
def __init__(self):
def init(self, msg):
# Exception.__init__(self, msg)
rospy.on_shutdown(self.cleanup)
self.voice = rospy.get_param("~voice", "voice_don_diphone")
self.wavepath = rospy.get_param("~wavepath", "")
# Create the sound client object
self.soundhandle = SoundClient()
rospy.sleep(1)
self.soundhandle.stopAll()
# Announce that we are ready for input
self.soundhandle.playWave(self.wavepath + "/R2D2a.wav")
rospy.sleep(1)
self.soundhandle.say("Ready", self.voice)
rospy.loginfo("Say commands...")
# Subscribe to the recognizer output
rospy.Subscriber('/recognizer/output', String, self.talkback)
# A mapping from keywords to commands.
self.keywords_to_command = {'plus': ['addition', 'add'],
'minus': ['subtraction', 'subtract'],
'devide': ['devision', 'by'],
'multiply': ['multiplication', 'into'],
# rospy.loginfo("Ready to receive voice commands")
def get_command(self, data):
for (command, keywords) in self.keywords_to_command.iteritems():
for word in keywords:
if data.find(word) > -1:
return command
def text2num(self, s):
a = re.split(r"[\s-]+", s)
n = 0
g = 0
for w in a:
x = Small.get(w, None)
if x is not None:
g += x
elif w == "hundred":
g *= 100
else:
x = Magnitude.get(w, None)
if x is not None:
n += g * x
g = 0
else:
raise NumberException("Unknown number: "+w)
return n + g
def talkback(self, msg):
command = msg.data
rospy.loginfo("Command: " + msg.data)
if 'plus' in command.split():
var1,var2= command.split("plus")
var1 = self.text2num(var1)
var2 = self.text2num(var2)
var3=sum(var1,var2)
self.soundhandle.say(var3, self.voice)
else:
return
def cleanup(self):
# When shutting down be sure to stop the robot! Publish a Twist message consisting of all zeros.
rospy.loginfo("Shutting down talkback node...")
if name=="main": rospy.init_node('talkback')
try:
TalkBack()
rospy.spin()
except:
pass
Originally posted by karan4515 on ROS Answers with karma: 73 on 2012-11-09
