I know that this question is common but I think that I've looked "all over" for an answer that works so if you have a minute would you mind checking out these config files for the nav stack? Everything seems to be working just great except for the goal achievement. I'm going to say that it gets to the (x,y) component fine but then it rotates back and forth. Ready... Set... Check my yaw_goal_tolerance :-) Just kidding, is it possible that the rotation actions being provided by the local planner are too coarse?
local_costmap:
  global_frame: /odom
  robot_base_frame: /base_link
  update_frequency: 5.0
  publish_frequency: 2.0
  static_map: false
  rolling_window: true
  width: 10.0
  height: 10.0
  origin_x: 0.0
  origin_y: 0.0
  resolution: 0.05
global_costmap:
  global_frame: /map
  update_frequency: 2.0
  publish_frequency: 10.0
  static_map: false
obstacle_range: 2.5
raytrace_range: 3.0
inflation_radius: 0.5
#---standard pioneer footprint---
#---(in meters)---
footprint: [ [0.254, -0.0508], [0.1778, -0.0508], [0.1778, -0.1778], [-0.32, -0.1778], [-0.32, 0], [-0.32, 0.1778], [0.1778, 0.1778], [0.1778, 0.0508], [0.254, 0.0508] ]
transform_tolerance: 0.5
map_type: costmap
observation_sources: scan
scan: {
      sensor_frame: base_laser,
      data_type: LaserScan,
      topic: scan,
      marking: true,
      clearing: true,
      expected_update_rate: 0.5
# Robot Configuration Parameters
acc_lim_x: 2.5
acc_lim_y: 2.5
acc_lim_th: 3.2
max_vel_x: 0.5
min_vel_x: 0.1
max_rotational_vel: 1.75
min_in_place_rotational_vel: 0.4
escape_vel: -0.1
holonomic_robot: false
# Goal Tolerance Parameters
xy_goal_tolerance: 0.5
yaw_goal_tolerance: 0.1
# Forward Simulation Parameters
sim_time: 1.7
sim_granularity: 0.025
vx_samples: 3
vtheta_samples: 20
# Trajectory Scoring Parameters
goal_distance_bias: 0.8
path_distance_bias: 0.6
occdist_scale: 0.01
heading_lookahead: 0.325
dwa: true
# Oscillation Prevention Parameters
oscillation_reset_dist: 0.05
If these settings look rather familiar it's because they're just about copied from the erratic navigation stack. And for completeness I've up'ed the xy_goal_tolerance to 0.5 and the yaw_goal_tolerance to 3.0 without having any improvement.
I saw that someone had an issue where they created a discrepancy between the resolutions of the map and costmaps?
So with that being said here are the parameters I'm feeding to gmapping:
<param name="sigma" value="0.05"/>
<param name="kernelSize" value="1"/>
<param name="lstep" value="0.05"/>
<param name="astep" value="0.05"/>
<param name="iterations" value="5"/>
<param name="lsigma" value="0.075"/>
<param name="ogain" value="3.0"/>
<param name="lskip" value="0"/>
<param name="srr" value="0.01"/>
<param name="srt" value="0.02"/>
<param name="str" value="0.01"/>
<param name="stt" value="0.02"/>
<param name="linearUpdate" value="0.5"/>
<param name="angularUpdate" value="0.436"/>
<param name="temporalUpdate" value="-1.0"/>
<param name="resampleThreshold" value="0.5"/>
<param name="particles" value="80"/>
<param name="xmin" value="-10.0" />
<param name="ymin" value="-10.0" />
<param name="xmax" value="10.0" />
<param name="ymax" value="10.0" />
<param name="delta" value="0.025"/>
<param name="llsamplerange" value="0.01"/>
<param name="llsamplestep" value="0.01"/>
<param name="lasamplerange" value="0.005"/>
<param name="lasamplestep" value="0.005"/>
Thank you so much for your help!!
Originally posted by skiesel on ROS Answers with karma: 549 on 2012-11-07
Comment by weiin on 2012-11-07:
Have you tried looking through this yet? http://ros.org/wiki/navigation/Tutorials/Navigation%20Tuning%20Guide
Comment by skiesel on 2012-11-13:
I had tried looking through it. But I wanted to make sure that I had tried everything. As far as I can tell I've played all the parameters in the known universe. I eventually thought that maybe my max/min acc and vel were off because it looked like the planner was "overshooting". Still didn't fixit
It looks like the issue was a namespacing problem. The TrajectoryPlannerROS was not receiving the correct parameters. The parameters were being loaded to /move_base but not /move_base/TrajectoryPlannerROS.
The solutions that I found were to either add "TrajectorPlannerROS:" to the top of the yaml file containing the parameters for the planner (in my case base_local_planner_params.yaml), just make sure that any parameters in the file have two spaces in front of them or you'll end up with a mysterious error when you try to launch.
TrajectoryPlannerROS:
Notice the two spaces in front of the parameter.
The second solution is to namespace the file when you load it, which allows you to reuse the file in multiple namespaces for common parameters. Inside of the launch file, inside of the move_base node:
<rosparam file="base_local_planner_params.yaml" command="load" ns="TrajectoryPlannerROS"/>
Originally posted by skiesel with karma: 549 on 2012-11-13
