This is sort of a follow up to this about libfreenect. I successfully got ROS installed on RaspberryPi (ARM) and compiled freenect_stack from @piyushk. I complete all of the steps, but it can't find the Kinect:
[kevin@raspberrypi freenect_stack]$ rosrun freenect_camera freenect_node
[ INFO] [1351981388.025719933]: Initializing nodelet with 1 worker threads.
[ INFO] [1351981396.302127503]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981399.320659202]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981402.339445895]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981405.356383634]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981408.375364319]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981411.394149012]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981414.413055699]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981417.431225405]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981420.453722998]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981423.472487689]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981426.493123329]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981429.516694892]: No devices connected.... waiting for devices to be connected
[ INFO] [1351981432.538032515]: No devices connected.... waiting for devices to be connected
Is there something else I am missing?
Originally posted by Kevin on ROS Answers with karma: 2962 on 2012-11-03
Comment by MarkyMark2012 on 2012-11-07:
Hi Kevin - any suggestions around a couple of problems I've having building this:libfreenect: No definition of [libxmu-dev] for OS [debian] freenect_launch: Missing resource pcl (I've installed libxmu-dev and freenect_camera: No definition of [log4cxx] for OS version [] where to get log4cxx?
and finally - MSG: gencfg_cpp on:Test.cfg CMake Error at cmake/cfgbuild.cmake:66 (string): string sub-command REPLACE requires at least four arguments. Thanks Mark
lsusb gives me - "Bus 001 Device 008: ID 045e:02b0 Microsoft Corp. Xbox NUI Motor" on the Pi
I don't have any experience with the RaspberryPi. I am not sure how well libfreenect supports it. Can you check to see if lsusb gives a suitable output:
lsusb
lsusb should give an output similar to:
Bus 001 Device 004: ID 045e:02b0 Microsoft Corp. Xbox NUI Motor
Bus 001 Device 005: ID 045e:02ad Microsoft Corp. Xbox NUI Audio
Bus 001 Device 006: ID 045e:02ae Microsoft Corp. Xbox NUI Camera
Also, I am not sure which binaries inside libfreenect can be run on the pi, but hopefully atleast tiltdemo should work:
rosrun libfreenect tiltdemo
Let me know if the above work.
Originally posted by piyushk with karma: 2871 on 2012-11-04
Comment by Kevin on 2012-11-10:
No I only see the Motor and the Audio and Camera don't show up. There appears to be others having the same issue, so I has more to do with the RaspberryPi and nothing to do with your code. Some people are thinking it has to do with the RPi's USB implementation.
Comment by MarkyMark2012 on 2012-11-20:
Kevin - should you find a solution to this please let me know - am looking into it myself can covered/built from scratch all suggestions I've found thus far..... Thanks Mark
Comment by Kevin on 2012-11-20:
doing more research, many have built libfreenect for RPi, but I cannot find anyone that has really gotten it to work. RPi can see the kinect motor but not the camera and audio. I think this is a RPi issue and not anything else. RPi probably has a bandwidth issue on the USB bus. Still looking at it.
Yep agreed - I'm getting the same issues as you...shall keep looking
Comment by MarkyMark2012 on 2012-11-25:
Kevin - by way of an update. Received new 512Mb board this w/e and updated the firmware. Now I'm able to see motor, audio and camera. A quick test of the tiltdemo also works. How did you get freenect_stack to build?
I get the following error: MSG: gencfg_cpp on:Test.cfg CMake Error at cmake/cfgbuild.cmake:66 (string): string sub-command REPLACE requires at least four arguments. Call Stack (most recent call first): cmake/cfgbuild.cmake:87 (gencfg_cpp) CMakeLists.txt:24 (include) when rosmake
Comment by Kevin on 2012-11-25:
Glad to hear you can see the camera now. I had no errors ... try opening a new question and posting the errors.
