Hello,
I have a iRobot Create that I wish to control using ROS. I have a Ubuntu 12.04 with ROS fuerte installed. From what I searched in the internet, I find that the brown university drivers for iRobot were developed for electric and there are no versions of that driver available for fuerte. However, I tried installing them using the following command,
sudo apt-get install ros-fuerte-brown-drivers
and the drivers installed successfully. After installing this I was able to successfully launch the "irobot_create_2_1" driver using the command
rosrun irobot_create_2_1 driver.py
Here's the problem. When I checked the info of the rosnode create, I get the following information.
ashok@nightFury:~$ rosnode info create
Node [/create]
Publications:
 * /rosout [rosgraph_msgs/Log]
Subscriptions: None
Services: None
contacting node http://nightFury:53815/ ...
Pid: 7310
Connections:
 * topic: /rosout
    * to: /rosout
    * direction: outbound
    * transport: TCPROS
However, according to tutorials that use the electric-brown-drivers, I should be getting the following information.
Node [/create]
Publications:
 * /sensorPacket [irobot_create_2_1/SensorPacket]
 * /odom [nav_msgs/Odometry]
 * /tf [tf/tfMessage]
Subscriptions:
 * /cmd_vel [unknown type]
Services:
 * /turn
 * /circle
 * /demo
 * /leds
 * /tank
 * /brake
 * /dock
contacting node http://ut-1215N:51148/ ...
Pid: 8218
Connections:
 * topic: /rosout
    * to: /rosout
    * transport: TCPROS
Can you please help me figure out why I'm not able to get the same information as the electric-brown-drivers? If there are other better ways to control the create can you also please guide me to them.
Thanks in advance, Ashok
Originally posted by Ashok Elluswamy on ROS Answers with karma: 1 on 2012-11-03
The maintainers of irobot_create_2_1 are no longer actively updating this package. I would recommend looking at the turtlebot_driver in the turtlebot stack for interfacing with the Create. If there is larger interest in using irobot_create_2_1, I can take a look at addressing this issue over the next few weeks.
Originally posted by odestcj with karma: 123 on 2012-11-04
Comment by River on 2013-01-15:
For future readers: Although turtlebot_driver is the underlying code for the create on the turtlebot stack, turtlebot_node is what you want.http://ros.org/wiki/turtlebot_node
