Hello all,
I am currently trying to rosmake the freenect_stack Piyush is maintaining. I downloaded the drivers on the desktop in the lab and they compiled fine. However, when I tried to compile on the laptop in the lab rosmake gave me the following errors (specifically in the libfreenect stack):
 [rosmake-0] Starting >>> libfreenect [ make ]
[ rosmake ] All 28 lines
  mkdir -p build/OpenKinect-libfreenect-9ab2c20/build
  cd build/OpenKinect-libfreenect-9ab2c20/build && cmake ../
  -- Operating system is Linux
  -- Got System Processor x86_64
  -- Linux x86_64 Detected
  -- libfreenect will be installed to /usr/local
  -- Headers will be installed to /usr/local/include/libfreenect
  -- Libraries will be installed to /usr/local/lib64
  CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
  Please set them or make sure they are set and tested correctly in the CMake files:
  GLUT_Xi_LIBRARY (ADVANCED)
      linked by target "glpclview" in directory /opt/ros/fuerte/stacks/freenect_stack/libfreenect/build/OpenKinect-libfreenect-9ab2c20/examples
      linked by target "glview" in directory /opt/ros/fuerte/stacks/freenect_stack/libfreenect/build/OpenKinect-libfreenect-9ab2c20/examples
      linked by target "hiview" in directory /opt/ros/fuerte/stacks/freenect_stack/libfreenect/build/OpenKinect-libfreenect-9ab2c20/examples
      linked by target "regview" in directory /opt/ros/fuerte/stacks/freenect_stack/libfreenect/build/OpenKinect-libfreenect-9ab2c20/examples
      linked by target "cppview" in directory /opt/ros/fuerte/stacks/freenect_stack/libfreenect/build/OpenKinect-libfreenect-9ab2c20/wrappers/cpp
  GLUT_Xmu_LIBRARY (ADVANCED)
  LIBUSB_1_LIBRARY
      linked by target "freenect" in directory /opt/ros/fuerte/stacks/freenect_stack/libfreenect/build/OpenKinect-libfreenect-9ab2c20/src
      linked by target "freenectstatic" in directory /opt/ros/fuerte/stacks/freenect_stack/libfreenect/build/OpenKinect-libfreenect-9ab2c20/src
[ rosmake ] Output from build of package libfreenect written to:
[ rosmake ]    /root/.ros/rosmake/rosmake_output-20121031-140959/libfreenect/build_output.log
[rosmake-0] Finished <<< libfreenect [FAIL] [ 0.10 seconds ]
[ rosmake ] Halting due to failure in package libfreenect.
[ rosmake ] Waiting for other threads to complete.
[ rosmake ] Results:
[ rosmake ] Built 1 packages with 1 failures.
[ rosmake ] Summary output to directory
Does anyone know what these errors are from? Thanks for all the help with these compiling issues.
Kind Regards, Martin
Originally posted by MartinW on ROS Answers with karma: 464 on 2012-10-31
The package has not compiled locally on your machine, so the the launch results in the above error. Try the system package ros-fuerte-freenect-stack. See http://www.ros.org/wiki/freenect_stack
Originally posted by piyushk with karma: 2871 on 2012-11-12
